18 Replies Latest reply on Aug 4, 2010 10:39 PM by getbestproduct
    Im a newbie: please help
    HumzaBobat
      Hi, no one is replying to my URGENT thread : http://forums.adobe.com/thread/693612
        • 1. Re: Im a newbie: please help
          i skipped your post because i don't download files.  and generally, the more you ask forum contributors to do, the less likely it is that you'll get help.
          if you throw up your hands and say, "i know nothing, help me", it's unlikely you'll get help and you should hire someone to do this for you.
          if you can do enough to pinpoint your problem it's highly likely you will be offered a solution to your problem via the flash forums.
          • 2. My New Problem
            HumzaBobat Level 1
            Now My Problem Is: is there an equivellant of the GET function [php] (that gets the but after the question mark e.g. it would get the following text "HelloWorld" from this url index.php?text=HelloWorld.) in ActionScript. sorry  if i explained it badly. if you have a solution please explain i t because i am a total newbie.
            • 3. Re: Im a newbie: please help
              you can use javascript to retrieve the url with query string (location.href)  and you can use the externalinterface class in flash to call a javascript function.  if you know there's exactly one variable/value, you can use:
              // in html
                 function locationF(){
                    return location.href;
              </script>
              // in flash
              var urlS:String = ExternalInterface.call("locationF");
              var queryS:String = urlS.substring(urlS.indexOf("?")+1);
              var queryA:Array = queryS.split("=");
              // queryA[0] will be your variable name (text, in your example);
              // queryA[1] will be your variable value (HelloWorld, in your example);
              • 4. Re: Im a newbie: please help
                iranten
                Kglad...loved that answer....i always wanted to say just whatyou did, but never had the guts.
                • 5. Re: Im a newbie: please help
                  HumzaBobat Level 1
                  iranten: i guess your only here to criticize me, i accept i made a mistake (mabe even a big one) and im sorry but this does not make me feel welcome.
                  Kglad: if you want you can give me instructions on how to make that code into text in adobe flash.
                  ive inserted the code into the first frame and the html file but nothing comes up in the flash document.Untitled.png
                  • 6. Re: Im a newbie: please help
                    iranten Level 1
                    Hi HumzaBobat,
                    Please....my apologies, that's not the way i meant it.
                    I learnt whatever I know about Flash, the hard Way....the same path that you are treading.
                    I am sure Kglad, didn't mean what he said, either.
                    What both of us are suggesting, is that you do some research before, you post a question - Don't just throw your hands up.
                    There's a much better Flash help site than this. Do check it out here:
                    http://www.flashkit.com/
                    You'll find me there under my same name.
                    And no..
                    no question is ever stupid....unless and untill, you never tried to find answers, by experimenting, but rather coming running straight to the board/forum
                    RanTen
                    • 7. Re: Im a newbie: please help
                      did you add the javascript?
                      • 8. Re: Im a newbie: please help
                        HumzaBobat Level 1
                        yes,
                        i thought it wouldnt work becuase there is no mention to display the text, is there a code to do that?
                        my source is :
                        <!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Strict//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-strict.dtd">
                        <html xmlns="http://www.w3.org/1999/xhtml" lang="en" xml:lang="en">
                             <head>
                                  <title>corrected-downloads</title>
                                  <meta http-equiv="Content-Type" content="text/html; charset=utf-8" />
                                  <style type="text/css" media="screen">
                                  html, body { height:100%; background-color: #333333;}
                                  body { margin:0; padding:0; overflow:hidden; }
                                  #flashContent { width:100%; height:100%; }
                                  </style>
                        </script>
                             </head>
                             <body>
                                  <div id="flashContent">
                                       <object classid="clsid:d27cdb6e-ae6d-11cf-96b8-444553540000" width="560" height="400" id="corrected-downloads" align="middle">
                                            <param name="movie" value="corrected-downloads.swf" />
                                            <param name="quality" value="high" />
                                            <param name="bgcolor" value="#333333" />
                                            <param name="play" value="true" />
                                            <param name="loop" value="true" />
                                            <param name="wmode" value="window" />
                                            <param name="scale" value="showall" />
                                            <param name="menu" value="true" />
                                            <param name="devicefont" value="false" />
                                            <param name="salign" value="" />
                                            <param name="allowScriptAccess" value="sameDomain" />
                                            <!--[if !IE]>-->
                                            <object type="application/x-shockwave-flash" data="corrected-downloads.swf" width="560" height="400">
                                            <!--<![endif]-->
                                                 <a href="http://www.adobe.com/go/getflash">
                                                      <img src="http://www.adobe.com/images/shared/download_buttons/get_flash_player.gif" alt="Get Adobe Flash player" />
                                                 </a>
                                            <!--[if !IE]>-->
                                            </object>
                                            <!--<![endif]-->
                                       </object>
                                  </div>
                             </body>
                        </html>
                        • 9. Re: Im a newbie: please help
                          good.  now, what do you expect to happen or what do you want to happen?
                          • 10. Re: Im a newbie: please help
                            HumzaBobat Level 1
                            i would like the text to be written as text in my swf file
                            like in php you echo or javascript you document.write.
                            sorry if im bothering you !
                            • 11. Re: Im a newbie: please help
                              what's the name of your textfield?  ie, it's instance name or reference?
                              • 12. Re: Im a newbie: please help
                                HumzaBobat Level 1
                                well make it abc
                                sorry for late reply!
                                • 13. Re: Im a newbie: please help
                                  use:
                                  abc.text = queryA[0]+" = "+queryA[1];
                                  • 14. Re: Im a newbie: please help
                                    HumzaBobat Level 1
                                    thanks very much
                                    • 15. Re: Im a newbie: please help
                                      you're welcome.
                                      please mark this thread as answered, if you can.
                                      • 16. Re: Im a newbie: please help
                                        HumzaBobat Level 1
                                        i tried but i cant find the two buttons anymore, maybe a moderator can close it and give credit to kglad
                                        • 17. Re: Im a newbie: please help
                                          no problem.  you tried.  that's good enough.
                                          • 18. Re: Im a newbie: please help
                                            getbestproduct
                                            Your question is not clear. ........
