0 Replies Latest reply on Aug 4, 2010 7:14 AM by Michel Reynard
    warning on xPath request in Flex4 when fine with Flex3
    Michel Reynard
      I'm upgrating from Flex 3 to Flex 4. Under Flex 3 I had no problem and no compilation error nor warning.
      On the following binding code:
      <mx:Binding source="this.model.appViewModel.appVO.translations.translation.(@language == this.model.appViewModel.appVO.currentLanguage).label.(@name == 'currentDate').@value" destination="this.inputDate.text"/>
      I get the following warning (the code is working fine):
      Multiple markers at this line:
      -Data binding will not be able to detect assignments to "name".
      -Data binding will not be able to detect assignments to "language".
      -model
      If I remove the attributes filter in my biding I don't get any warning
      <mx:Binding  source="this.model.appViewModel.appVO.translations.translation.label.@value" destination="this.inputDate.text"/>
      I get more than 200 warning because of this...
      Any idea?
      The translation is an xml data defined here
      [Bindable]
      public class AppVO
              private var _translations     :XML              = <translations/>;
              public function get translations():XML {return this._translations;}
              public function set translations(value:XML):void {this._translations = value;}
