4 Replies Latest reply on Aug 5, 2010 7:45 AM by RobRZDZ
    htmlFileToPDF only works with a ZIP file
    RobRZDZ Level 1
      Hello everybody.
      I'm writing a simple Java program with Eclipse as to test the htmlFileToPDF API call.
      According to the docs, this API ""Creates a PDF document from an input HTML file or a ZIP file containing HTML files and/or Image files. For ZIP files, this method searches the ZIP contents for the index.html file. It then uses the index.html as the document root."
      So I created a simple Java program (mostly taken from http://help.adobe.com/en_US/livecycle/9.0/programLC/help/000213.html#1548718 - Converting HTML content to a PDF document using the Java API) but it only seems to work when the inputDocument is a ZIP file which contains the index.html file.
      As an examples, considering the following lines:
              FileInputStream is = new FileInputStream("C:\\index.html");
           Document inHTML = new Document(is);
           HtmlToPdfResult result = pdfGenClient.htmlFileToPDF(
                inHTML,
      With the above example, when the class executes I got the following exception:
           ALC-PDG-080-019-Input file File.zip does not contain the index html file
      If I change the first line to read
              FileInputStream is = new FileInputStream("C:\\test.zip");
      and the test.zip file does contain the index.tml file, everything works as expected.
      What am I missing?
      Rob
        • 1. Re: htmlFileToPDF only works with a ZIP file
          Jasmin Charbonneau Level 4
          Use  htmlToPDF instead of htmlFileToPDF.
          Jasmin
          • 2. Re: htmlFileToPDF only works with a ZIP file
            RobRZDZ Level 1
            Hi Jasmin!
            First of all, thank you for your reply.
            Well, far from me from being a nitpicker but isnt's htmlToPDF supposed to perform an HTML -> PDF conversion of an URL?
            According to the docs, htmlToPDF "creates a PDF document from an HTML file located at a given URL"; the input parameter inputURL is the URL of the HTML page you want to convert.
            OK, even files on a filesystem can be can be accessed as URLs but is there something wrong with the htmlFileToPDF API?
            I'm new to LCES2 so I might be wrong but, from the docs, I thought htmlFileToPDF was well suited for what I was trying to achieve; or perhaps the doc for this API has to be amended?
            Rob
            • 3. Re: htmlFileToPDF only works with a ZIP file
              I though you wanted to create it from a URL sorry. I just glanced through the post.
              The documentation is fine. htmlFileToPDF can convert html content.
              The trick is you need to put it in a document variable (com.adobe.idp.Document) and set a property to a temporary  name so it knows it's a single file and not a zip.
              Document htmlDoc = new Document(htmlContent.getBytes());
              htmlDoc.setAttribute("file", "Temp.html");
              Jasmin
              • 4. Re: htmlFileToPDF only works with a ZIP file
                RobRZDZ Level 1
                Hi Jasmin.
                No need to apologize and thanks for your help.
                I'm pretty new with LCES2 APIs so I did not pay enough attention to the setAttibute() method; by following your example, everything now works as expected.
                Rob
