1. Re: Legacy channel shortcuts issue?
SG... Aug 4, 2010 1:16 PM (in response to Howard Rudnick)Hi Howard,
Changing to the Legacy shortcuts changes the Curves adjustment panel on my 10.6.4 and 10.5.8 12.0.1 installs (2-->~, 3-->1, etc.). I did note that the Help document has a copy error with the modifier key, but that's different from what you're experiencing.
Are you running the 12.0.0 or 12.0.1 version, 32bit or 64 bit, and on what OS version? With your other posts, it almost sounds like you may be running into permissions issues, and don't have write priviledges on a few files.
regards,
steve
2. Re: Legacy channel shortcuts issue?
Howard Rudnick Aug 5, 2010 8:16 AM (in response to SG...)Steve-IT dept did the install, but I know that it's 12.0.1, and the OS was updated to snow leopard. This was all last friday. My issue with the color ring is cleared up. Issue with patterns is weird since I was able to load brushes and actions from cs3. I haven't tried gradients yet. Your first paragraph confuses me, are you using opt or command key with #s to pick channels in curves? When I use command in curves, that channel is targeted visually, but I have to use opt to target channel and make changes in curves dialog. thanks
