7 Replies Latest reply on Aug 15, 2010 5:09 AM by RealBillyBlue
    'if...' in ItemRenderer?
    RealBillyBlue
      Hey there,
      is it possible to use 'if..' in an ItemRenderer?
      I've to show products in a SList. Every product has multiple colors. The DB gives true/false as information (which color is available) like this:
      productname:text
      blue:true
      black:true
      white:false
      And I want to show the colors (as a little colored box) under the product-picture. I've got everything done fine, but this colorthing.
      So I thought I could done this maybe with something like 'if (blue) ...' but this seems not to work or I've did it wrong.
      Maybe someone of you could help me?
      I hope I could explain what I try to do (with my bad english ^^)
      Thank you!!
      - BB
        • 1. Re: 'if...' in ItemRenderer?
          saisri2k2 Level 4
          Yes, you cn use if in the itemrenderer. But please put it in the following block in the custom itemrenderer that you write.
          //you need to ovverride the data prop in the itemrenderer
          override public function set data(value:Object):void
          if(logic goes here){
          //set color herer
          }else if(){
          anothre color
          • 2. Re: 'if...' in ItemRenderer?
            RealBillyBlue Level 1
            Thank you, but if it is separated from s:layout, how could I add a colored box into the s:list?
            <s:ItemRenderer xmlns:fx="http://ns.adobe.com/mxml/2009"
                                xmlns:mx="library://ns.adobe.com/flex/mx"
                                autoDrawBackground="true">
                 <s:layout>
                      <s:VerticalLayout paddingBottom="5" paddingLeft="5" paddingRight="5" paddingTop="5"/>
                 </s:layout>
                 <s:Label text="{data.productname}" fontWeight="bold"/>
                 <mx:Image source="pix/{data.picfile}.jpg" width="100" height="100"/>
            </s:ItemRenderer>
            So where I've to put your code now?
            • 3. Re: 'if...' in ItemRenderer?
              BhaskerChari Level 4
              Hi RealBillyBlue,
              Write a Script block in your itemRenderer file and put the override function in that block....as shown below:
                   <fx:Script>
                      <![CDATA[
                //set color herer
                }else if(){
                anothre color
                  </fx:Script>
                   <s:layout>
                   </s:layout>
              </s:ItemRenderer>
              Bhasker Chari
              • 4. Re: 'if...' in ItemRenderer?
                Ok, maybe I did told you correct where my (new) problem is, because of my not so good english
                If I do it like you told me in your last answer, how I'll get the color into my s:list via this ItemRenderer? I know how to set/give back a s:label or mx:image as you can see in my code, but what have to be in the if-logic that gives back a colored box, which will appears under the picture from ' <mx:Image source="pix/{data.picfile}.jpg" width="100" height="100"/>' ?
                • 5. Re: 'if...' in ItemRenderer?
                  David_F57 Level 5
                  hi,
                  You can play with this and see if it meets what you need, the way I did the color boxes can be done differently (such as use the color flag to make visible true or false). I elected to use width as sometimes objects can leave gaps rather than totally disappear when visible is false.
                  David
                     xmlns:mx="library://ns.adobe.com/flex/mx" minWidth="955" minHeight="600">
                  <fx:Declarations>
                  <!-- Place non-visual elements (e.g., services, value objects) here -->
                  </fx:Declarations>
                  <fx:Script>
                  <![CDATA[
                  import mx.collections.ArrayCollection;
                  [Bindable] private var myProducts:ArrayCollection = new ArrayCollection([
                  {ID:"P01",IMG:null,RED:true,BLUE:true,GREEN:false,YELLOW:true,BLACK:true,WHITE:true},
                  {ID:"P02",IMG:null,RED:true,BLUE:false,GREEN:true,YELLOW:true,BLACK:true,WHITE:true},
                  {ID:"P03",IMG:null,RED:true,BLUE:true,GREEN:true,YELLOW:true,BLACK:true,WHITE:true},
                  {ID:"P04",IMG:null,RED:true,BLUE:true,GREEN:true,YELLOW:true,BLACK:true,WHITE:true},
                  {ID:"P05",IMG:null,RED:false,BLUE:true,GREEN:true,YELLOW:true,BLACK:true,WHITE:true},
                  {ID:"P06",IMG:null,RED:true,BLUE:true,GREEN:true,YELLOW:true,BLACK:true,WHITE:true}
                  </fx:Script>
                  <s:List x="87" y="85" width="627" height="140" dataProvider="{myProducts}" itemRenderer="ProductRender">
                  <s:layout>
                  <s:HorizontalLayout/>
                  </s:layout>
                  </s:List>
                  </s:Application>
                  renderer
                  autoDrawBackground="true" width="100" height="120">
                  <s:VGroup width="100%" height="100%">
                  <mx:Image source="{data.IMG}" left="2" right="2" top="2" height="100%"/>
                  <s:Label width="100%" text="{data.ID}" textAlign="center"/>
                  <s:HGroup width="100%" height="16" paddingLeft="2" paddingRight="2" gap="0">
                  <s:Rect height="16" width="{data.WHITE ? 16 : 0}">
                  <s:fill>
                  <s:SolidColor color="0xFFFFFF"/>
                  </s:fill>
                  </s:Rect>
                  <s:Rect height="16" width="{data.BLACK ? 16 : 0}">
                  <s:fill>
                  <s:SolidColor color="0x000000"/>
                  </s:fill>
                  </s:Rect>
                  <s:Rect height="16" width="{data.RED ? 16 : 0}">
                  <s:fill>
                  <s:SolidColor color="0xFF0000"/>
                  </s:fill>
                  </s:Rect>
                  <s:Rect height="16" width="{data.GREEN ? 16 : 0}">
                  <s:fill>
                  <s:SolidColor color="0x00FF00"/>
                  </s:fill>
                  </s:Rect>
                  <s:Rect height="16" width="{data.BLUE ? 16 : 0}">
                  <s:fill>
                  <s:SolidColor color="0x0000FF"/>
                  </s:fill>
                  </s:Rect>
                  </s:HGroup>
                  </s:VGroup>
                  </s:ItemRenderer>
                  • 6. Re: 'if...' in ItemRenderer?
                    Thank you! I'll try this today or tomorrow!
                    • 7. Re: 'if...' in ItemRenderer?
                      Thank you! It works perfect!
