5 Replies Latest reply on Aug 5, 2010 9:59 AM by Hjalmar Molin
    Video-sound sync problem
    Hjalmar Molin Level 1
      I have the problem that the Canon EOS 5D Mark II does not sync video and audio from the start. The sound comes before the event. I have to adjust the audio channel by moving it forward when I edit in Premiere Pro CS5. Is it a bug in the software for the camera? I have firmware version 2.0.7. The result is the same whether I use the built-in microphone or a wireless connection. Maybe not a problem with Premiere. Have more than I have had this problem?
      Wiew: http://vimeo.com/13888863
        • 1. Re: Video-sound sync problem
          What are the video settings, and what is your project preset?
          Have you tried dragging and dropping a file on the new item icon in CS5?
          • 2. Re: Video-sound sync problem
            the_wine_snob Level 9
            Obviously, addressing the OOS issue at the start is the best course of action. However, if one needs to make the sync adjustment during post, this ARTICLE might prove useful.
            Now, there have been many posts on the Canon 5D/7D footage, but I do not recall any regarding OOS. Maybe I just missed those?
            I would look first to the Project Preset, and hope that with the proper Preset, matching the source footage 100%, the OOS issues will disappear.
            Most OOS seems to come from muxed MPEG material, or WMV material, and then with some H.264 material, but usually with Export.
            Good luck, and please keep the reports coming,
            • 3. Re: Video-sound sync problem
              Type: MPEG Movie
              File Size: 1,0 GB
              Image Size: 1920 x 1080
              Pixel Depth: 32
              Frame Rate: 25,00
              Source Audio Format: 48000 Hz - compressed - Stereo
              Project Audio Format: 48000 Hz - 32 bit floating point - Stereo
              Total Duration: 00:03:04:18
              Average Data Rate: 5,6 MB / second
              Pixel Aspect Ratio: 1,0
              Video Display format: Timecode
              Audio Display format: Milliseconds (but even Audio Samples with the same resutat)
              Capture Format: HDV
              Preset Desciption: For editing most DSLR Formats (like the Canon EOS Movie Full HD series) recorded in 1920x1080 square pixels (non-anamorphic).
              16:9 Progressive HD video at 25 frames per second. 48 kHz audio.
              General
              Editing mode: DSLR
              Timebase: 25,00fps
              Video Settings
              Frame size: 1920h 1080v (1,0000)
              Frame rate: 25,00 frames/second
              Pixel Aspect Ratio: Square Pixels (1.0)
              Fields: No Fields (Progressive Scan)
              Audio Settings
              Sample rate: 48000 samples/second
              Default Sequence
              Total video tracks: 3
              Master track type: Stereo
              Mono tracks: 0
              Stereo tracks: 3
              5.1 tracks: 0
              Submix mono tracks: 0
              Submix stereo tracks: 0
              Submix 5.1 tracks: 0
              No
              • 4. Re: Video-sound sync problem
                OK, one quick question: I see that the Audio source is "Compressed." Is this AIFF?
                What happens if you convert that source Audio to PCM/WAV (Uncompressed) with the same specs.? Notice PCM and not Linear WAV. First, I would do a Render/Replace of the Audio stream, to see if that changes things. If not, then I'd rip the Audio in a program like Audition, do a Save_As PCM/WAV and Import that into the Project, to replace the original Audio stream.
                PrPro (and Audition) seems to have issues with AIFF (and MP3), so I am just guessing here.
                • 5. Re: Video-sound sync problem
                  I chose codec AAC,  but there is also the option AAC+1 or AAC+2. What is that? I also chose Frequensy 48 Khz.
