2 Replies Latest reply on Aug 9, 2010 1:40 AM by Vie Bone
    set alpha.state with as3
    Vie Bone Level 1
      Hello!
      Someone know if there is a way to set a property of a dynamic created spark object for a specific state via as3
      Some thing like this:
      <s:SkinnableContainer id="mycontainer" alpha.state1 = "0">
      </SkinnableContainer>
      But via AS3
      var sc:SkinnableContainer = new SkinnableContainer();
      sc.state1.alpha = 0;
      Obviously the code above is wrong, but i was trying to find the way to do that.
      Thanks a lot.
        • 2. Re: set alpha.state with as3
          Vie Bone Level 1
          Thanks, very helpful.
          I add some post that talks about the same problem and was helpful for me:
          http://blogs.adobe.com/flexdoc/2010/08/creating-flex-view-states-in-actionscript.html#comm ent-506
          http://www.andymcintosh.com/?p=5
          http://forums.adobe.com/message/1868208#1868208
          http://livedocs.adobe.com/flex/3/langref/mx/states/SetProperty.html
          I solved my problem doing this:
          <s:Group xmlns:fx="http://ns.adobe.com/mxml/2009"
          xmlns:mx="library://ns.adobe.com/flex/mx" height="100%" width="100%" creationComplete="loadXML()" >
          <fx:Metadata>
          [Event(name="menuItemSelected", type="MenuItemSelectedEvent")]
          </fx:Metadata>
          <fx:Script>
          <![CDATA[
          import mx.controls.Alert;
          import mx.states.*;
          import spark.components.Label;
          import spark.components.VGroup;
          private var xmlData:XML;
          private var s1:State;
          private var vGroupArr:Array = new Array();
          protected function loadXML():void
          var urlrequest:URLRequest = new URLRequest("../data/categories.xml");
          var urlloader:URLLoader = new URLLoader();
          urlloader.addEventListener(Event.COMPLETE, urlLoaderComplete);
          urlloader.load(urlrequest);
          protected function urlLoaderComplete(evt:Event):void
          xmlData = new XML(evt.target.data);
          addElements();
          protected function addElements():void
          var categories:XMLList = xmlData.category;
          s1 = new State();
          s1.name = "DEFAULT_STATE";
          states = new Array();
          states.push(s1);
          for each (var e:XML in xmlData.elements()){
          //Create MXML Objects
          var categoryButton:Label = new Label();
          var projectsGroup:VGroup = new VGroup();
          //Add properties to the label
          categoryButton.id = e.@id;
          categoryButton.name = e.@name;
          categoryButton.text = e.@name;
          categoryButton.buttonMode = true;
          categoryButton.addEventListener(MouseEvent.CLICK,expandSubMenu);
          //Add new element to the container
          navigationContainer.addElement(categoryButton);
          //Add properties to the VGroup
          projectsGroup.id = "submenu_" + e.@name;
          projectsGroup.paddingLeft = 15;
          projectsGroup.gap = 0;
          vGroupArr.push(projectsGroup);
          //Set default properties for the defoult_state
          s1.overrides.push(new SetProperty(projectsGroup,"alpha",0));
          s1.overrides.push(new SetProperty(projectsGroup,"height",0));
          //Create each submenu states
          s1 = new State();
          s1.name = e.@name;
          states.push(s1);
          //Loop for the projects of each category
          for each (var o:XML in xmlData.category[e.childIndex()].elements())
          //Create the project label and asign properties to it
          var projectButton:Label = new Label();
          projectButton.id = o.@id;
          projectButton.name = o.@name;
          projectButton.text = o.@name;
          projectButton.buttonMode = true;
          projectsGroup.addElement(projectButton);
          projectButton.addEventListener(MouseEvent.CLICK,menuClickHandler);
          if(!currentState) currentState = "DEFAULT_STATE";
          setStates();
          protected function setStates():void
          for(var z:Number = 0; z < vGroupArr.length; z++)
          for(var x:Number = 1; x < states.length-1; x++)
          if(("submenu_" + states[x].name) != vGroupArr[z].id)
          states[x].overrides.push(new SetProperty(vGroupArr[z],"alpha",0));
          states[x].overrides.push(new SetProperty(vGroupArr[z],"height",0));
          }else
          //Alert.show("submenu_" + states[x].name + " == " + vGroupArr[z].id );
          protected function expandSubMenu(event:MouseEvent):void
          var eventName:String = event.currentTarget.name;
          currentState=(currentState == eventName) ? "DEFAULT_STATE" : eventName ;
          Alert.show(states[0].overrides);
          protected function menuClickHandler(event:MouseEvent):void
          //trace(event.target.id);
          var menuEvent:MenuItemSelectedEvent = new MenuItemSelectedEvent(MenuItemSelectedEvent.MENU_ITEM_SELECTED, event.target.id);
          dispatchEvent(menuEvent);
          </fx:Script>
          <!-- STATES -->
          <s:states>
          <s:State name="allCollapsed"/>
          <s:State name="subMenu1Expanded"/>
          <s:State name="subMenu2Expanded"/>
          </s:states>
          <!-- TRANSITIONS -->
          <!-- CONTENT -->
          <s:Group>
          <!-- Background -->
          <s:Rect top="5" bottom="5" left="5" right="5>
          <s:fill>
          <s:SolidColor color="0x222222"/>
          </s:fill>
          <s:stroke>
          <s:SolidColorStroke color="0x444444" weight="2"/>
          </s:stroke>
          </s:Rect>
          <!-- Menu Items -->
          <s:VGroup id="navigationContainer" paddingBottom="15" paddingLeft="15" paddingRight="15" paddingTop="5" gap="0"> <!-- gap must be 0; see note in CSS file -->
          </s:VGroup>
          </s:Group>
          </s:Group>
