This content has been marked as final.
Show 1 reply
1. Re: How is the Insert > Form dialog done?
Randy Edmunds Aug 5, 2010 10:12 AM (in response to ac361)I love the way the Insert > Form dialog looks but can't figure out how it was done.
Here's how you can find the code for anything done through a DW Menu (which is almost everything).
Start by opening this file in a text editor:
[install-dir]/configuration/menus/menus.xml
This file defines all DW Menus. About 2/3 way through the file you'll find this comment:
<!-- This is the Main menu bar -->
Everything above that comment are context (right-click) menus. The <menubar> tag defines the main menu. Insert menu is <menu id="DWMenu_Insert">. The Form item is <menuitem id="DWMenu_Insert_Form"> which has file="Forms/Form.htm" that maps to:
configuration/Objects/Forms/Form.htm
HTH,
Randy
