8 Replies Latest reply on Aug 28, 2008 1:13 AM by almond0517
    Problems defining properties of custom components
    manicati
      I have created a Flash component for Flex. In the AS3 file I have the following code:
      package {
      import flash.display.*
      import flash.text.*
      import mx.flash.UIMovieClip;
      import flash.net.URLRequest;
      import flash.events.*;
      public class mirrorImageHome extends UIMovieClip
      // Define public setter method.
      [Bindable (event="loadBgImage")]
      public function set bgImage(img:String):void
      this.testTXT.text = img;
      dispatchEvent(new Event("loadBgImage"));
      The component works fine in Flex, but the problem is that it only works when my property is static:
      Works:
      <FlashComps:mirrorImageHome y="150" bgImage="TEST" includeInLayout="false" />
      Does not work:
      <FlashComps:mirrorImageHome y="150" bgImage="{'TEST'}" includeInLayout="false" />
      I know, the curly braces have no effect in this case. It's only to illustrate that the property does not accept dynamic data.
      Did I something wrong with the AS3?
      Can anyone help me, please?
