0 Replies Latest reply on Aug 5, 2010 3:22 PM by RoC1909
    "Validate Failed" error message.
    RoC1909
      REPOSTED IN THE PROPER FORUM
      Hello all....again.
      I am creating a form that has 4 columns (Meals, Lodging, Misc & Total Amt) and each column has 15 rows.
      I used javascript to calculate the total amount of the rows across into the "Total Amount" column as below:
           $.rawValue = Meals1.rawValue + Lodg1.rawValue + Misc1.rawValue)
      Then I have the very bottom RIGHT field add the "Total Amount" fields together to get the COMPLETE AMOUNT.
      What  is happening is that MEALS, LODGING & MISC fields display correctly  (using a currency pattern) and the TOTAL AMOUNT fields calculate  correctly....except when the TOTAL AMOUNT goes over 99,999.99. It is  then that I get the "fieldname Validate Failed" error.
      I  have all the fields set up as a "Numeric Field" with the "Display,  Edit, Validation & Data PATTERNS" set as "num.currency{}"
      I can't for the life of me figure out why I cannot add anything over 99,999.00 dollars.
      If anyone can help with this, it would be much appreciated.
