10 Replies Latest reply on Aug 9, 2010 4:57 AM by Abhin S
    How to show all the controls used in a text area in an mxml file
    Abhin S
      kindly help me to show all the controls used in a file like buttons, text box, combobox,
      in a text area to denote tht these controls were used in the flex file
        • 1. Re: How to show all the controls used in a text area in an mxml file
          BhaskerChari Level 4
          Hi Abhin S,
          Your question is not clear ...please elaborate on this..??
          Bhasker Chari.S
          • 2. Re: How to show all the controls used in a text area in an mxml file
            Abhin S Level 1
            Hi Bhasker Chari.S,
            i have created a mxml file in which i have used certain controls like buttons, link buttons, combobox,textarea etc.
            nw i want to show all the controls used in my file in a textarea. so that one is able to see what features i used in document..
            thnx fr ur concern..
            • 3. Re: How to show all the controls used in a text area in an mxml file
              Hi Abhin S,
              If I understood correctly you want to display the whole mxml file in TextArea...?...If so then this is not possible
              I suggest you that you can display the contents of this file in a Container such as Canvas, HBox or VBox instead of TextArea..
              or else Do you want to display just the Control names used in the mxml file in a TextArea..?? However it is possible..??
              Can you post the code what exactly you're trying to achieve..??
              Bhasker Chari
              Message was edited by: BhaskerChari
              • 4. Re: How to show all the controls used in a text area in an mxml file
                Abhin S Level 1
                yes i want the names of the controls used i.e button,combobox,textarea,link.
                this is the code:
                <s:Application minWidth="955" minHeight="600"
                xmlns:fx="http://ns.adobe.com/mxml/2009"
                    xmlns:mx="library://ns.adobe.com/flex/mx"
                    initialize="createListener()">
                <fx:Declarations>
                </fx:Declarations>
                <fx:Script>
                    <![CDATA[
                        import spark.events.IndexChangeEvent;
                        // Define a custom function for the labelFunction property
                        // to display an Object in the DDL control.
                        public function myLabelFunc(item:Object):String {
                             return item.firstName + " " + item.lastName;
                        // Define a custom function for the labelToItemFunction property
                        // to convert the new value to an Object of the correct format
                        // for storage in the data provider of the control.
                        public function myLabelToItemFunc(value:String):Object {
                             var tempObj:Object = new Object();
                             var spaceChar:int = value.indexOf(' ');
                             tempObj.firstName = value.substr(0, spaceChar);
                             tempObj.lastName = value.substr(spaceChar+1, value.length);
                             return tempObj;
                             // Event handler to determine if the selected item is new.
                            protected function myCB_changeHandler(event:IndexChangeEvent):void
                                 // Determine if the index specifies a new data item.
                                 if(myCB.selectedIndex == spark.components.ComboBox.CUSTOM_SELECTED_ITEM)
                                     // Add the new item to the data provider.
                                     myCB.dataProvider.addItem(myCB.selectedItem);
                        import spark.components.ComboBox;
                       private function setLabel():void {
                            if (l2.label=="Show ComboBox") {
                                l2.label = "Show TextBox";
                                               } else {
                                l2.label = "Show ComboBox";
                          private function createListener():void {
                                l2.addEventListener(MouseEvent.CLICK,showCustomBox);
                          import mx.controls.Alert;
                          private function showCustomBox(e:MouseEvent):void{
                          t2.text += " listener." + "\n";
                          Alert.show("An event occurred.");
                </fx:Script>
                    <s:states >
                    <s:State name="Immediate"/>
                    <s:State name="Deferred"/>
                    </s:states>
                <s:BorderContainer borderColor="#0b85b7"
                    cornerRadius="8"
                    borderWeight="4">
                <s:VGroup top="10" horizontalAlign="center" >
                <s:ComboBox id="myCB"
                            includeIn="Immediate"
                            itemCreationPolicy="immediate"
                            labelFunction="myLabelFunc"
                labelToItemFunction="myLabelToItemFunc"
                change="myCB_changeHandler(event);">
                           <s:dataProvider>
                           <mx:ArrayCollection>
                            <fx:Object firstName="Abhinav" lastName="Somal"/>
                            <fx:Object firstName="Adit" lastName="Kumar"/>
                            </mx:ArrayCollection>
                          </s:dataProvider>
                        </s:ComboBox>
                        <s:TextInput id="t1"
                            includeIn="Deferred"
                            itemCreationPolicy="deferred"/>
                        <mx:LinkButton id="l2" label="Show TextBox"
                          click="currentState='Deferred';setLabel();"/>
                        <s:TextArea id="t2"
                        text="The selected item is: {myCB.selectedItem.firstName + ' '
                        + myCB.selectedItem.lastName};
                        {l2.label};
                        {b1.label};
                <mx:Button id="b1" label="SEND"  >
                </mx:Button>
                </s:VGroup>
                </s:BorderContainer>
                </s:Application>
                • 5. Re: How to show all the controls used in a text area in an mxml file
                  Hi Abhin,
                  This involves a complex looping ....as your nesting of controls with in containers increases.....If your nesting of controls is simple say you are having all your controls with in a single container or few then  the below code may be helpful....
                  <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml"
                    creationComplete="init();">
                    <mx:Script>
                      <![CDATA[
                        import mx.core.Container;
                        private function init():void{
                          checkChildren(this);
                        private function checkChildren(objToCheck:Object):void{
                                  for each(var obj:Object in objToCheck.getChildren()){
                            if(obj is Container){
                              mx.controls.Alert.show("Container:" + obj.toString());
                              checkChildren(obj);
                            }else{
                              mx.controls.Alert.show("Not container:" + obj.toString());
                    </mx:Script>
                    <mx:VBox>
                      <mx:Button id="btn1"/>
                      <mx:CheckBox id="chbx"/>
                      <mx:ComboBox>
                        <mx:String>one</mx:String>
                        <mx:String>two</mx:String>
                        <mx:String>three</mx:String>
                      </mx:ComboBox>
                    </mx:VBox>
                    <mx:Canvas>
                         <mx:Button id="btn2"/>
                    </mx:Canvas>
                  </mx:Application>
                  Bhasker Chari
                  • 6. Re: How to show all the controls used in a text area in an mxml file
                    Abhin S Level 1
                    thnx fr ur previous suggestion bt still m nt able to implement it.
                    this is the new code kindly check wht is the problem::-
                    <fx:Declarations>
                    </fx:Declarations>
                    <fx:Script>
                        <![CDATA[
                                 return tempObj;
                                                   } else {
                                checkChildren(obj);
                              }else{
                    </fx:Script>
                        <s:states >
                        </s:states>
                        cornerRadius="8"
                        borderWeight="4">
                    <mx:VBox top="10" horizontalAlign="center" >
                               <s:dataProvider>
                              </s:dataProvider>
                            </s:ComboBox>
                            <s:TextArea id="t2"
                            {l2.label};
                            {b1.label};
                    </mx:Button>
                    </mx:VBox>
                    </s:Application>
                    • 7. Re: How to show all the controls used in a text area in an mxml file
                      Abhin S Level 1
                      Hi Bhasker Chari,
                      the code you have given is having mx:Application declareation
                      why can not we use s:Application declaration here
                      • 8. Re: How to show all the controls used in a text area in an mxml file
                        Hi Abhin,
                        mx:Application  declaration is for Flex3...
                        s:Application declaration is for Flex4 which is used in FlashBuilder4 IDE
                        But the logic in Actionscript remains same..
                        Bhasker Chari
                        • 9. Re: How to show all the controls used in a text area in an mxml file
                          Abhin S Level 1
                          i am using flex4 and there i am not able to implement it.
                          here is the code:
                          • 10. Re: How to show all the controls used in a text area in an mxml file
                            Abhin S Level 1
                            thnks.
                            problem is solved..
                            correct code:
                            <mx:Application
                              <mx:states >
                                <mx:State name="si"/>
                                <mx:State name="re"/>
                              </mx:states>
                              <fx:Script>
                                <![CDATA[
                                        checkChildren(obj);
                                      }else{
                                         return tempObj;
                              </fx:Script>
                                        includeIn="si"
                                       <s:dataProvider>
                                      </s:dataProvider>
                                    </s:ComboBox>
                                        includeIn="re"
                                      <mx:LinkButton label="show text box"
                                            click="currentState = 're'" includeIn="si"/>
                                      <mx:LinkButton label="show combobox"
                                            click="currentState = 'si'"
                                            includeIn="re"/>
                                    <s:TextArea id="t2"
                                    + myCB.selectedItem.lastName};"/>
                            </mx:Button>
                            </mx:VBox>
                            </mx:Application>
