0 Replies Latest reply on Aug 6, 2010 1:59 AM by Abhin S
    to implement two functions from a link button
    Abhin S
      i have created a script:
      <s:Application minWidth="955" minHeight="600"
      xmlns:fx="http://ns.adobe.com/mxml/2009"
          xmlns:mx="library://ns.adobe.com/flex/mx"
          initialize="createListener()">
      <fx:Declarations>
      </fx:Declarations>
      <fx:Script>
          <![CDATA[
              import spark.events.IndexChangeEvent;
              // Define a custom function for the labelFunction property
              // to display an Object in the DDL control.
              public function myLabelFunc(item:Object):String {
                   return item.firstName + " " + item.lastName;
              // Define a custom function for the labelToItemFunction property
              // to convert the new value to an Object of the correct format
              // for storage in the data provider of the control.
              public function myLabelToItemFunc(value:String):Object {
                   var tempObj:Object = new Object();
                   var spaceChar:int = value.indexOf(' ');
                   tempObj.firstName = value.substr(0, spaceChar);
                   tempObj.lastName = value.substr(spaceChar+1, value.length);
                   return tempObj;
                   // Event handler to determine if the selected item is new.
                  protected function myCB_changeHandler(event:IndexChangeEvent):void
                       // Determine if the index specifies a new data item.
                       if(myCB.selectedIndex == spark.components.ComboBox.CUSTOM_SELECTED_ITEM)
                           // Add the new item to the data provider.
                           myCB.dataProvider.addItem(myCB.selectedItem);
              import spark.components.ComboBox;
             private function setLabel():void {
                  if (l2.label=="Show ComboBox") {
                      l2.label = "Show TextBox";
                                     } else {
                      l2.label = "Show ComboBox";
                private function createListener():void {
                      l2.addEventListener(MouseEvent.CLICK,showCustomBox);
                import mx.controls.Alert;
                private function showCustomBox(e:MouseEvent):void{
                t2.text += " listener." + "\n";
                Alert.show("An event occurred.");
      </fx:Script>
          <s:states >
          <s:State name="Immediate"/>
          <s:State name="Deferred"/>
          </s:states>
      <s:BorderContainer borderColor="#0b85b7"
          cornerRadius="8"
          borderWeight="4">
      <s:VGroup top="10" horizontalAlign="center" >
      <s:ComboBox id="myCB"
                  includeIn="Immediate"
                  itemCreationPolicy="immediate"
                  labelFunction="myLabelFunc"
      labelToItemFunction="myLabelToItemFunc"
      change="myCB_changeHandler(event);">
                 <s:dataProvider>
                 <mx:ArrayCollection>
                  <fx:Object firstName="Abhinav" lastName="Somal"/>
                  <fx:Object firstName="Adit" lastName="Kumar"/>
                  </mx:ArrayCollection>
                </s:dataProvider>
              </s:ComboBox>
              <s:TextInput id="t1"
                  includeIn="Deferred"
                  itemCreationPolicy="deferred"/>
              <mx:LinkButton id="l2" label="Show TextBox"
                click="currentState='Deferred';setLabel();"/>
              <s:TextArea id="t2"
              text="The selected item is: {myCB.selectedItem.firstName + ' '
              + myCB.selectedItem.lastName};
              {l2.label};
              {b1.label};
      <mx:Button id="b1" label="SEND"  >
      </mx:Button>
      </s:VGroup>
      </s:BorderContainer>
      </s:Application>
      in this i changed the link label,but i am not able to get back the dropdown list ..
      kindly help..
