2 Replies Latest reply on Aug 6, 2010 11:20 AM by teknix1
    DSC Exports
    teknix1
      Hi All,
      I've been creating DSCs in which I set the supports-export element to "true". This is supposed to trigger my DSC to be exported whenever a LiveCycle archive is created (of an application which makes use of my DSC obviously). But somehow this does not work. I can rename the lca to a zip to look into it and my files are never there. Does this functionnality actually work or am i doing something wrong?
      Here's the contents of my component.xml:
      <component xmlns="http://adobe.com/idp/dsc/component/document">
          <component-id>Test</component-id>
          <version>1.0</version>
          <supports-export>true</supports-export>
          <services>
              <service name="Test" orchestrateable="true" title="Test">
                  <implementation-class>com.livecycle.test.Test</implementation-class>
                  <auto-deploy major-version="1" minor-version="0" category-id="Test" />
                  <operations>
                      <operation name="Test1" method="Test1">
                          <input-parameter name="test" type="int" required="true" title="test">
                              <supported-expr-types>Variable,XPath,Literal,Template,</supported-expr-types>
                          </input-parameter>
                          <output-parameter name="output" title="output" type="int">
                              <supported-expr-types>XPath,Variable</supported-expr-types>
                          </output-parameter>
                      </operation>
                  </operations>
              </service>
          </services>
      </component>
      As always any help is greatly appreciated!
      Nic
