0 Replies Latest reply on Aug 2, 2007 8:25 AM by T Hinds
    Using Perforce
    T Hinds
      In RHv5, I've moved from WinHelp to HTMLHelp. Since there's a whole lot more source files, I wanted to link RH to Perforce to automatically use source control.
      I set up the Perforce within RH and added the project files. That seemed to work fine.
      Now when I open the project, it looks like RH is creating a temporary file that is not in the project folder structure and giving the following error.
      Path 'c:\Documents and Settings\thinds\Local Settings\Temp\pv129.htm' is not under client's root 'C:\dev'.
      I have to click through related or repeated messages 11 times, so it's pretty annoying. Then when I try to compile, I get the following error:
      Path 'c:\Documents and Settings\thinds\Local Settings\Temp\Tmp22035.chm' is not under client's root 'C:\dev'.
      Can someone tell me what I'm doing wrong?
      Thanks for your help,
      - Tom
