3 Replies Latest reply on Aug 9, 2010 3:13 AM by anilreddy_narra
    need help on flex3- Click events
    anilreddy_narra
      Hello,
      I have created a loosly coupled presentation layer using c# and flex. The previous project was in visual studio. It was tightly coupled layer. The present application is loosly coupled. I have chosen flex as a presentation layer,c# as a business layer and XML as the data source. The application is regarding student modules in a university. I have 2modules(workbooks) in my project .Each modules has its own workpage. Each page has objectives, Theory,modules guide, references.....etc in each page. I have created 7 web services using c#(Business layer) and XML(getMenu, getTheory,getObjectives,getPractices, getLinks, getAssessments,getModulesGuide). I didn't use any user interface controls.
      getMenu is the menu item(Main modules-Database system and developing web application using asp.net). Each modules has 3 work pages. Each work page has objectives,theory...etc). I took objectives as the labels.
      <mx:VBox
      label="Objectives">
      <mx:Label
      id="lblObj" text="Objectives" visible="false" styleName="linkList" fontFamily="Arial" fontSize="30" textAlign="left" />
      <mx:Repeater
      id="rp2" width="800">
      <mx:Text
      id="txtObj" text="{rp2.currentItem.objective_content}" width="800" enabled="true" fontFamily="Arial" textAlign="left" fontSize="14"/>
      </mx:Repeater>
      </mx:VBox>
      <mx:VBox
      label="Theory">
      <mx:Label
      text="Theory" id="lblTheory" visible="false" styleName="linkList" fontFamily="Arial" fontSize="30" textAlign="left"/>
      <mx:Repeater
      id="rp" width="950">
      <mx:VBox
      <mx:Label
      id="lblid" text="{rp.currentItem.body_frag_title}" fontWeight="bold" enabled="true" fontFamily="Arial" textAlign="left" fontSize="14"/>
      <mx:Text
      text="{rp.currentItem.body_frag_text}" width="950" enabled="true" fontFamily="Arial" textAlign="left" fontSize="14"/>
      </mx:VBox>
      </mx:Repeater>
      </mx:VBox>
      I need little bit help from u. If i click on objectives it should displays only objectives information. If i click on the theory it should displays only objectives information.
      Note: some pages have no objectives, some have no theory..etc
      Thank you
        • 2. Re: need help on flex3- Click events
          BhaskerChari Level 4
          Hi Anil,
          Put your Objectives and Theory VBoxes in TabNavigtor as shownb below...
          <mx:TabNavigator
          resizeToContent="true">
          <mx:VBox label="Objectives">
          <mx:Label id="lblObj" text="Objectives" visible="false" styleName="linkList" fontFamily="Arial" fontSize="30" textAlign="left" />
          <mx:Repeater id="rp2" width="800">
          <mx:Text id="txtObj" text="{rp2.currentItem.objective_content}" width="800" enabled="true" fontFamily="Arial" textAlign="left" fontSize="14"/>
          </mx:Repeater>
          </mx:VBox>
          <mx:VBox label="Theory">
          <mx:Label text="Theory" id="lblTheory" visible="false" styleName="linkList" fontFamily="Arial" fontSize="30" textAlign="left"/>
          <mx:Repeater id="rp" width="950">
          <mx:VBox>
          <mx:Label id="lblid" text="{rp.currentItem.body_frag_title}" fontWeight="bold" enabled="true" fontFamily="Arial" textAlign="left" fontSize="14"/>
          <mx:Text text="{rp.currentItem.body_frag_text}" width="950" enabled="true" fontFamily="Arial" textAlign="left" fontSize="14"/>
          </mx:VBox>
          </mx:Repeater>
          </mx:VBox>
          </mx:TabNavigator>
          Bhasker Chari
          • 3. Re: need help on flex3- Click events
            anilreddy_narra Level 1
            I have 4more operations(Module Guide, Practices,Assessments and Research Links) other than objectives and theory.
            What about the other operations?
            I have 6pages. One page has only objectives, theory and references, another page has objectives, theory, Module Guide and references, another page has only assessments and references...etc
            Some pages have no Theory information and some other have no Asessments information, If I put all the operations in tab navigator..
            Anil
