3 Replies Latest reply on Aug 7, 2010 7:38 AM by bnemeth
    Error occured opening file...Please help!
    bnemeth
      Good morning everyone,
      I have an .fla file that I've been working on for hours and hours. Everything seemed to be fine when I went to bed last night, but I woke up this morniong to find I can't open the file, I get the message "An eror occurred openning file 'C:\users....'.
      Is there any way I can fix this? I need the file for an interview Monday morning. It still needs a lot of work and I'm really stressing. Thanks for any help anyone can offer!
      bee
        • 1. Re: Error occured opening file...Please help!
          if you haven't already tried,
          1.  right click your fla and click open with (and select flash).  if that fails:
          2.  with flash open, click file/open and navigate to your fla.  if that fails:
          3.  move your fla to another directory and try 1 and then 2.  if those fail:
          4.  rename your moved fla (with the same file extension) and try 1 and then 2.
          if all those fail, upload your fla to a server and post a link.
          • 2. Re: Error occured opening file...Please help!
            bnemeth Level 1
            Thanks, but no luck :-(
            I just tried creating an entirely new document as well, saved every couple of minutes and everything seemed to be working fine. I closed and reopened and got the same message on that file.
            I'm working on the trial version, in case that gives anyone any other ideas...
            • 3. Re: Error occured opening file...Please help!
              bnemeth Level 1
              also, if it helps anyone to better understand the issue...it seems like the
              file works perfectly until I close flash and try reopenning it.
              cs5 trial version, issue has occurred on two files now
              thanks again for any help!
