9 Replies Latest reply on Aug 10, 2010 5:43 AM by ocphotog
    Parsing a filename script
    ocphotog
      HI,
      I'm trying to take the image filename and parse it so that I only get the pose number left. For example: the filename is Jones12345_002.jpg. I only want to get the 002 part of the filename. I've looked at the addfilename scripts but haven't found anything that will separate the name.
      I've tried this code but it seems to skip the parsing code I added:
      //start code
      // this script is a variation of the script addTimeStamp.js that is installed with PH7
      if ( documents.length > 0 )
      var originalRulerUnits = preferences.rulerUnits;
      preferences.rulerUnits = Units.PIXELS;
      try
        var docRef = activeDocument;
        // Now create a text layer at the front
        var myLayerRef = docRef.artLayers.add();
        myLayerRef.kind = LayerKind.TEXT;
        myLayerRef.name = "Filename";
        var myTextRef = myLayerRef.textItem;
        // strip the extension off
        var fileNameNoExtension = docRef.name;
        fileNameNoExtension = fileNameNoExtension.split( "." );
        if ( fileNameNoExtension.length > 1 ) {
         fileNameNoExtension.length--;
        fileNameNoExtension = fileNameNoExtension.join(".");
        myTextRef.contents = fileNameNoExtension;
      // test trimming filename to last 3 characters
      var sFileName = " ";
      yStr = myTextRef.contents;
      function getFname(yStr) {
      for (nloop=yStr.length-1;nloop>1;nloop--) {
          if (yStr.charAt (nloop) =="_") {
            sFileName=yStr.substring(nloop+1,yStr.length);
             break;
      return sFileName;
      myTextRef.contents = sFileName;
      // end trimming filename to last 3 characters
        // off set the text to be in the middle
        myTextRef.position = new Array( docRef.width / 2, docRef.height / 2 );
        myTextRef.size = 20;
      catch( e )
        // An error occurred. Restore ruler units, then propagate the error back
        // to the user
        preferences.rulerUnits = originalRulerUnits;
        throw e;
      // Everything went Ok. Restore ruler units
      else
      alert( "You must have a document open to add the filename!" );
      //end code
      Thanks for any help
        • 1. Re: Parsing a filename script
          Paul Riggott Level 6
          Here is an example...
          var file = File( "/c/folder/folder2/Jones12345_002.jpg");
          var Name =  decodeURI(file.name).replace(/\.[^\.]+$/, '');
          var lastNumbers = Name.match(/\d+$/);
          alert(lastNumbers);
          • 2. Re: Parsing a filename script
            ocphotog Level 1
            Hi Paul,
            thanks for your quick response but I'm a bit confused with your code (Newbie here!) I have a file open in photoshop and I want to add a text layer to the file that just has the last 3 numbers of the filename in it. I think the code you provided is a bit more than I need. Can you help me parsing name of the open file?  Thanks in advance
            • 3. Re: Parsing a filename script
              Okay here is your code with the modification...
              try
              var Name =  decodeURI(docRef.name).replace(/\.[^\.]+$/, '');
              var fileNameNoExtension = Name.match(/\d+$/).toString();
              catch( e )
                // to the user
                throw e;
              else
              //end code
              • 4. Re: Parsing a filename script
                ocphotog Level 1
                Paul, THANK YOU, THANK YOU! It works perfectly. I wasted 5 hours and wasn't even close to getting it.
                • 5. Re: Parsing a filename script - Got a glitch
                  ocphotog Level 1
                  Hi Paul,
                  Got the last 3 numbers to show up fine but now I came across a glitch. If I have a filename that is  "  Jones12345_002BW.jpg or  Jones12345_002_BG  "  I get an error that says "Error 54 Uncaught Javascript exception: TypeError: null is not an object. Line 37  -> throw e; "
                  I know it's from the BW or the _BG added. Is there a way to make an    if/else statement to account for those two events along with the regular Jones12345_002.jpg that I'll be encountering?
                  Hoping you can help me once again.
                  Mark
                  • 6. Re: Parsing a filename script - Got a glitch
                    Please try this now, just one more line added
                    try
                    Name = Name.replace(/[a-zA-Z_]+$/gi,'');
                    catch( e )
                      // to the user
                      throw e;
                    else
                    //end code
                    Or condense it down....
                    if ( documents.length > 0 ){
                    try{
                    myTextRef.contents =  decodeURI(docRef.name).replace(/[a-zA-Z_\.]+$/gi,'').match(/\d+$/).toString();
                    }catch( e ){
                      throw e;
                    }else{
                    • 7. Re: Parsing a filename script - Got a glitch
                      ocphotog Level 1
                      Hi Paul,
                      Thanks again for jumping in and helping. I think I didn't make myself clear enough though. What you gave me does get rid of anything after the 3 number pose but what I really needed was to have the script be able to display any of the following:
                      original filename: Jones12345_003.jpg.    result needed:  003
                      original filename: Jones12345_003BW.jpg    result needed:  003BW
                      original filename: Jones12345_003_BW.jpg   result needed: 003_BW
                      This would allow me to send it any file and have it give back the filenumber after the " _  " so that I can have some images in color with the pose # and some images that may be in B&W also show the pose# and the BW.
                      Hope you can help again.  Thanks
                      Mark
                      • 8. Re: Parsing a filename script - Got a glitch
                        Sorry about that (Its old age ) Please try this now..
                        try{
                        var Numbers =  decodeURI(docRef.name).replace(/[a-zA-Z_\.]+$/gi,'').match(/\d+$/).toString();
                        var End =  decodeURI(docRef.name).replace(/\.[^\.]+$/, '').toString().match(/[^\d]+$/);
                        var Name ='';
                        if(End != null) {
                             Name = Numbers +End;
                             }else{
                                  Name = Numbers;
                        myTextRef.contents =  Name;
                        }catch( e ){
                          throw e;
                        }else{
                        • 9. Re: Parsing a filename script - Got a glitch
                          ocphotog Level 1
                          Paul, Thank you again. It's perfect! Not sure how it all works but it does the job just as I need it to.
                          Mark
