3 Replies Latest reply on Aug 7, 2010 10:47 PM by Andrei1
    Remove spaces in text variable
    Chemistry guy
      I'm slowly converting my older Director-made tutorials to Flash. The user inputs text, and then I evaluate it. Before this evaluation, I want to remove spaces to avoid the user's input being counted incorrect because of an extra space. How do I do this for Flash CS5?
      Here's what I did for Director.
      TermNoSpaces = gTerm
      spaceChar = numToChar(32) --routine to remove spaces from the user input
      if TermNoSpaces contains spaceChar then
           repeat while TermNoSpaces contains spacChar
                lessSpace = offset(spaceChar, TermNoSpaces)
                delete TermNoSpaces.char[lessSpace]
                put TermNoSpaces
           end repeat
      end if
        • 1. Re: Remove spaces in text variable
          Deepanjan Das Level 3
          Use trim function:
          * Removes any extra spaces before and after a String
          * @param: value:String – value to be trimmed
          * @return: String value – the trimmed value
          public function trim(value:String):String{
          var j:uint = 0;
          while (value.charAt(j) == ” “){
          j++
          value = value.substring(j);
          var k:uint = value.length – 1;
          while(value.charAt(k) == ” “){
          k–
          value = value.substring(0, k+1)
          return value;
          Hope this helps.
          Warm Regards
          Deepanjan Das
          http://deepanjandas.wordpress.com/
          • 2. Re: Remove spaces in text variable
            Andrei1 Level 6
            The best approach to manipulate strings is using regular expressions.
            This code trims string off spaces on both ends:
            var str:String = " this is string ";
            var trim:RegExp = /^ +| +$/g;
            str = str.replace(trim, "");
            trace("BEGIN" + str + "END");
            This eliminates all the spaces:
            var space:RegExp = /\s/g;
            str = str.replace(space, "");
            trace(str);
            This code replaces multiple spaces with a single space:
            var str:String = "this   string      with       many       spaces";
            var singleSpace:RegExp = /\s{2,}/g;
            str = str.replace(singleSpace, " ");
            trace(str);
            • 3. Re: Remove spaces in text variable
              Andrei1 Level 6
              Actually I think this is more correct:
              var trim:RegExp = /^\s+|\s+$/g;
