4 Replies Latest reply on Aug 12, 2010 1:38 AM by RealBillyBlue
    How to build a simple 'designer'?
    RealBillyBlue
      Hey there,
      I'm on Flex 4 and I try to build a little designer for my shopsystem. Just some little things like 'set your text' (ideal would be free position w/ mouse-move) and maybe picture-upload with mouse-positioning.
      After the user set the text/pic, I want to use AlivePDF (http://alivepdf.bytearray.org/) for PDF-Output on server to send it via email automatically to me.
      Does anybody know a tutorial for this or an openSource solution?
      I think about using an array to store the users steps (such us one line text is one array-entry) and after the user has finished, a function read out this array and transfer it into a PDF.
      Any ideas are welcome
      - bb
        • 1. Re: How to build a simple 'designer'?
          RealBillyBlue Level 1
          No one has an idea? -.-
          • 2. Re: How to build a simple 'designer'?
            rtalton Level 4
            You're covering a lot of ground here with very little information regarding your design requirements...
            Let's break this down:
            Moving things around on the stage: search the help docs for "drag and drop". Fairly simple to accomplish.
            'set your text': Not sure what this means. Allow user to type text into an editable TextArea, perhaps?
            Uploading pictures: This depends on your back-end technology-- PHP? .NET? or ??? Use Google to search for "Flex file upload using PHP" or whatever you are using.
            "Alive PDF-Output on server": Not sure what this means. I use Alive PDF in Flex, and it allows saving the PDF to user's HDD using a FileReference class, OR, opening the created PDF in a browser. I don't think you can save it to your server, unless you again resort to a file upload after saving it to the user's HDD, or perhaps sending it as a byte array w/o saving it locally. Search for this topic at AlivePDF site?
            Sending PDF via email: Never tried this, sorry can't help you there. If you can somehow get the file uploaded to your server, you will need a back-end solution to then retrieve it and email it to yourself.
            HTH
            • 3. Re: How to build a simple 'designer'?
              UbuntuPenguin Level 4
              Like rtalton said , you are covering a lot of ground.  I have used alive pdf, and it is possible to save the pdf to the backend.  You have to create the pdf on the client , convert it to Base64 and send to your backend.
              • 4. Re: How to build a simple 'designer'?
                Thank you both for your answer. I'll try to explain it more:
                For the 'drag and drop' with editable Text I found a solution, that seems to work fine for me.
                Pictures > I'm on PHP and sure I'll try Google
                (may the most important) convert it to an PDF: What I need is a solution like AlivePDF (or itself) which allows me to create a PDF like I want in and send it via Email from the backend to a special email-address. So as I can see AlivePDF doesn't support this directly and Flex itself also doesn't (which is unbelievable, because it is both from Adobe now!).
                Maybe there is a backend like AlivePDF in PHP or something like this, which I can use or maybe you can explain me a bit more about this BASE64 way, because I've never done something like this before.
                Or maybe - if this would be much easier - it would also help to create TIFF or high resolution JPEG instead PDF.
                Thank you!!
                - bb
