3 Replies Latest reply on Aug 14, 2010 2:56 PM by Чернявский
    Save datagrid contents to SQLite
    Чернявский
      Hi All!
      I have a datagrid with a unknown number of rows....How can I can I dynamically save all the data to a SqLite database,and also update the database when the user changes a value(s)...
      Are there any examples of something like this out there.
        • 1. Re: Save datagrid contents to SQLite
          wise_qwerty
          What language are you using for the back-end? examples:php, java,...
          Often back-end language works with all database stuff, not flex. Flex is just front-end (GUI).
          • 2. Re: Save datagrid contents to SQLite
            Чернявский Level 1
            I use a local SQLite database for desktop applications without the use of php, java.
            • 3. Re: Save datagrid contents to SQLite
              Чернявский Level 1
              <s:WindowedApplication
              xmlns:fx="http://ns.adobe.com/mxml/2009"
              xmlns:s="
              library://ns.adobe.com/flex/spark"
              xmlns:mx="
              library://ns.adobe.com/flex/mx"
              width="
              800" height="600"
              creationComplete="onCreationComplete()"
              <fx:Script>
              <![CDATA[
              import mx.controls.Alert;
              import mx.events.DataGridEvent;
              import mx.collections.ArrayCollection;
              Bindable]
              public var dp:ArrayCollection = new ArrayCollection();
              private var connection:SQLConnection;
              public var dbStatement:SQLStatement;
              public var dbFile:File;
              public var dbFileString:String = "exampledb.db";
              public function onCreationComplete():void
              connection =
              new SQLConnection();
              //@lis dbFile = File.applicationStorageDirectory.resolvePath(dbFileString);
              dbFile = File.desktopDirectory.resolvePath(dbFileString);
              // does the database exist?
              if(dbFile.exists)
              // the database exists, so let's open it and read in the data
              connection.open(dbFile);
              loadData();
              else {
              // the database does not exists, so let's create it
              createDB();
              public function createDB():void
              connection.addEventListener(SQLEvent.OPEN, onDBCreateResult);
              connection.addEventListener(SQLErrorEvent.ERROR, onDBError);
              // the following line creates the database if it does not exists, but we already know it doesn't
              private function onDBCreateResult(event:SQLEvent):void
              // we successfully created the database, so let's create our table
              createTable();
              For this example we can use this error result handler for all our transactions
              private function onDBError(event:SQLErrorEvent):void
              Alert.show(event.error.name +
              " " + event.error.errorID + "\n" +
              event.error.details +
              "\n" + event.error.message);
              public function createTable():void
              var sql:SQLStatement = new SQLStatement();
              sql.sqlConnection = connection;
              var sqlString:String = "CREATE TABLE Users (" +
              " uid INTEGER PRIMARY KEY AUTOINCREMENT, " +
              " name TEXT, " +
              " phonemob TEXT, " +
              " phonewrk TEXT, " +
              " phonehom TEXT)";
              sql.text = sqlString;
              sql.addEventListener(SQLEvent.RESULT, onDBCreateTableResult);
              sql.addEventListener(SQLErrorEvent.ERROR, onDBCreateTableError);
              sql.execute();
              sqlString =
              "INSERT INTO Users (name, phonemob, phonewrk, phonehom) " +
              "VALUES ('Чернявский А.В.', '099-99999999', '99999999', '9999999')";
              //sql.addEventListener(SQLEvent.RESULT, onDBAddResult);
              sql.addEventListener(SQLErrorEvent.ERROR, onDBError);
              sql.execute();
              private function onDBCreateTableResult(event:SQLEvent):void
              trace('table created');
              loadData();
              private function onDBCreateTableError(event:SQLErrorEvent):void
              trace(event.error.name + " " + event.error.errorID + "\n" +
              private function loadData():void
              dbStatement =
              new SQLStatement();
              dbStatement.sqlConnection = connection;
              var sqlQuery:String = "select * from Users";
              dbStatement.text = sqlQuery;
              dbStatement.addEventListener(SQLEvent.RESULT, onRetrieveDataResult);
              dbStatement.addEventListener(SQLErrorEvent.ERROR, onDBError);
              dbStatement.execute();
              private function onRetrieveDataResult(event:SQLEvent):void
              var result:SQLResult = dbStatement.getResult();
              dp =
              for each(var el:Object in result.data)
              dp.addItem({ uid:el.uid, name:el.name, phonemob:el.phonemob, phonewrk:el.phonewrk, phonehom:el.phonehom });
              trace('cache retrieved');
              public function add():void
              dbStatement =
              new SQLStatement();
              var sqlString:String = "INSERT INTO Users (name, phonemob) " +
              "VALUES ('наберите ФИО', '0XX-YYYYYYY')";
              sql.addEventListener(SQLEvent.RESULT, onDBAddSuccess);
              sql.execute();
              public function onDBAddSuccess(event:SQLEvent):void
              var uid:Number = event.currentTarget.sqlConnection.lastInsertRowID;
              loadData();
              public function remove():void
              var selectedItemUid:Number = dg.selectedItem.uid;
              var selectedIndex:Number = dg.selectedIndex;
              if(selectedIndex >= 0)
              dbStatement =
              new SQLStatement();
              var sqlString:String = "DELETE FROM Users WHERE uid=" + selectedItemUid;
              sql.addEventListener(SQLEvent.RESULT, onDBRemoveResult);
              sql.execute();
              else {
              Alert.show(
              "You do not have a row selected to delete.");
              public function onDBRemoveResult(event:SQLEvent):void
              loadData();
              public function update(event:DataGridEvent):void
              dbStatement =
              new SQLStatement();
              var sqlString:String = "UPDATE Users SET name = '" + event.itemRenderer.data.name +
              "', phonemob = '" + event.itemRenderer.data.phonemob +
              "', phonewrk = '" + event.itemRenderer.data.phonewrk +
              "', phonehom = '" + event.itemRenderer.data.phonehom +
              "' WHERE uid = " + event.itemRenderer.data.uid;
              sql.execute();
              </fx:Script>
              <mx:DataGrid id="dg" itemFocusOut="update(event)"
              dataProvider="
              {dp}"
              editable="
              true"
              wordWrap="
              true" variableRowHeight="true"
              left="
              5" right="5" top="150" bottom="5">
              <mx:columns>
              <mx:DataGridColumn editable="false" dataField="uid" headerText="Номер" width="30"/>
              <mx:DataGridColumn editable="true" dataField="name" headerText="ФИО" width="200" />
              <mx:DataGridColumn editable="true" dataField="phonemob" headerText="Телефоны мобильные" />
              <mx:DataGridColumn editable="true" dataField="phonewrk" headerText="Телефоны рабочие" />
              <mx:DataGridColumn editable="true" dataField="phonehom" headerText="Телефоны домашие" />
              </mx:columns>
              </mx:DataGrid>
              <s:Button y="100" click="add()" label="Добавить строку" right="5"/>
              <s:Button y="72" click="remove()" label="Удалить строку" right="5" enabled="{dg.selectedIndex != -1}"/>
              </s:WindowedApplication>
