1 Reply Latest reply on Aug 21, 2007 2:54 PM by batmitra
    local FILEUPLOAD without webserver
    irie7even
      hello everyone!
      I am searching quite a long time for this topic but I couldn't find a proper solution.
      I am creating a flex applicationen where the user should be able to upload files (*.jpeg, *.png, *.gif) locally (application on a CD, user wants to browse and add a picture).
      Does anyone know how to do this. Everything should work locally without internet connection.
      thanks for your help.
      irie7even
        • 1. Re: local FILEUPLOAD without webserver
          batmitra Level 1
          hi
          the short answer is, you can't do it, why? because uploading files is intended to be made to a server or with a server as a middleware guy. So to upload a file you need a backend script using .net languages ,php, or others.
          If all you want is to allow your client to see some images on a cd you can put on your cd an xml file with the paths to your images and then load them.
