5 Replies Latest reply on Aug 9, 2010 5:38 AM by rootsounds
    Populate datagrid and draw linechart based on xmlList
    asifdegr8 Level 1
      I am generating dynamic xml structure like this
      <root>
        <OPVector>
          <Distance>0</Distance>
          <Height1>100</Height1>
          <Height2>200</Height2>
          <Height3>300</Height3>
        </OPVector>
        <OPVector>
          <Distance>100</Distance>
          <Height1>200</Height1>
          <Height2>300</Height2>
          <Height3>400</Height3>
        </OPVector>
        <OPVector>
          <Distance>200</Distance>
          <Height1>300</Height1>
          <Height2>400</Height2>
          <Height3>500</Height3>
        </OPVector>
      </root>
      What i have to do is to populate data grid based on this xml structure and draw a line chart where distance is category axis (x-axis) and Height1, Height2 etc are line series . No of Height fields depends on how many height values are entered by user (in text field Height1, Height2, Height3, Height4, Height5,Height6).
      Given is the code of my application ....
      <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml" layout="absolute" width="905" height="482" creationComplete="init();">
      <mx:Script>
      <![CDATA[
      import mx.events.IndexChangedEvent;
      private var dataProvider:XMLList = new XMLList();
      private var initDist:int ;
      private var offset:int  ;
      private var finalDist:int;
      private var height1:int;
      private var height2:int;
      private var height3:int;
      private var height4:int;
      private var height5:int;
      private var height6:int;
      private var heat:int;
      private var dataOP:XMLList;
      public function init():void{
      initDist = parseInt(txtInitDist.text);
      offset = parseInt(txtOffset.text);
      finalDist = parseInt(txtFinalDist.text);
      height2 = parseInt(txtHeight1.text);
      height2 = parseInt(txtHeight2.text);
      height3 = parseInt(txtHeight3.text);
      height4 = parseInt(txtHeight4.text);
      height5 = parseInt(txtHeight5.text);
      height6 = parseInt(txtHeight6.text);
      heat = parseInt(txtHeat.text);
      public function getOP():void{
      dataOP = createXMLObject();
      currentState='stateOP';
      trace(dataOP.toXMLString());
      } // public function getOP():void{
      public function createXMLObject():XMLList{
      var data:XMLList = XMLList(<root></root>);
      for (var i:int=initDist;i<=finalDist;i+=offset){
      var x:XMLList = new XMLList(<OPVector></OPVector>);
      var distance:String = "<Distance>"+i+"</Distance>";
      var strHeight1:String = "<Height1>"+(parseInt(txtHeight1.text)+i)+"</Height1>";
      var strHeight2:String = "<Height2>"+(parseInt(txtHeight2.text)+i)+"</Height2>";
      var strHeight3:String = "<Height3>"+(parseInt(txtHeight3.text)+i)+"</Height3>";
      var strHeight4:String = "<Height4>"+(parseInt(txtHeight4.text)+i)+"</Height4>";
      var strHeight5:String = "<Height5>"+(parseInt(txtHeight5.text)+i)+"</Height5>";
      var strHeight6:String = "<Height6>"+(parseInt(txtHeight6.text)+i)+"</Height6>";
      x.appendChild(distance);
      if (txtHeight1.text != ""){
      x.appendChild(strHeight1);
      if (txtHeight2.text != ""){
      x.appendChild(strHeight2);
      if (txtHeight3.text != ""){
      x.appendChild(strHeight3);
      if (txtHeight4.text != ""){
      x.appendChild(strHeight4);
      if (txtHeight5.text != ""){
      x.appendChild(strHeight5);
      if (txtHeight6.text != ""){
      x.appendChild(strHeight6);
      data.appendChild(x);
      } // for (var i:int=initDist;i<finalDist;i+=offset){
      return data;
      } // public function createXMLObject():void
      </mx:Script>
      <!-- States Definition -->
      <mx:states>
      <mx:State name="stateOP">
      <mx:RemoveChild target="{btnOP}"/>
      <mx:RemoveChild target="{btnThermal}"/>
      <mx:RemoveChild target="{txtHeight5}"/>
      <mx:RemoveChild target="{txtHeight6}"/>
      <mx:RemoveChild target="{txtFinalDist}"/>
      <mx:RemoveChild target="{label1}"/>
      <mx:RemoveChild target="{label2}"/>
      <mx:RemoveChild target="{label3}"/>
      <mx:RemoveChild target="{txtHeight3}"/>
      <mx:RemoveChild target="{txtHeight4}"/>
      <mx:RemoveChild target="{txtOffset}"/>
      <mx:RemoveChild target="{label4}"/>
      <mx:RemoveChild target="{label5}"/>
      <mx:RemoveChild target="{label6}"/>
      <mx:RemoveChild target="{txtHeight1}"/>
      <mx:RemoveChild target="{txtHeight2}"/>
      <mx:RemoveChild target="{txtInitDist}"/>
      <mx:RemoveChild target="{label7}"/>
      <mx:RemoveChild target="{label8}"/>
      <mx:RemoveChild target="{label9}"/>
      <mx:RemoveChild target="{txtHeat}"/>
      <mx:RemoveChild target="{label13}"/>
      <mx:AddChild position="lastChild">
      <mx:DataGrid x="57" y="112" width="274" height="336" id="dgPressure" dataProvider="{dataOP}">
      <mx:columns>
      <mx:DataGridColumn headerText="Column 1" dataField="col1"/>
      <mx:DataGridColumn headerText="Column 2" dataField="col2"/>
      <mx:DataGridColumn headerText="Column 3" dataField="col3"/>
      </mx:columns>
      </mx:DataGrid>
      </mx:AddChild>
      <mx:LineChart x="382" y="112" id="lcOverPressure" width="513" height="182">
      <mx:series>
      <mx:LineSeries displayName="Series 1" yField=""/>
      </mx:series>
      </mx:LineChart>
      </mx:AddChild>
      <mx:Legend dataProvider="{lcOverPressure}" x="810" y="51"/>
      </mx:AddChild>
      <mx:Button x="382" y="426" label="Close" id="btnClose" click="currentState=''"/>
      </mx:AddChild>
      </mx:State>
      <mx:State name="stateTR">
      <mx:DataGrid x="39" y="108" width="301" height="364">
      <mx:columns>
      </mx:columns>
      </mx:DataGrid>
      </mx:AddChild>
      <mx:LineChart x="420" y="108" id="linechart1" width="475" height="181">
      <mx:series>
      </mx:series>
      </mx:LineChart>
      </mx:AddChild>
      <mx:Legend dataProvider="{linechart1}" x="810" y="13"/>
      </mx:AddChild>
      </mx:State>
      </mx:states>
      <!-- Controls Definition -->
      <mx:TextInput x="331" y="95" width="62" id="txtHeat" text="8"/>
      <mx:TextInput x="231" y="229" width="62" id="txtHeight1" text="100"/>
      <mx:TextInput x="231" y="259" width="62" id="txtHeight3" text="300"/>
      <mx:TextInput x="231" y="289" width="62" id="txtHeight5"/>
      <mx:TextInput x="357" y="229" width="62" id="txtHeight2" text="200"/>
      <mx:TextInput x="357" y="259" width="62" id="txtHeight4"/>
      <mx:TextInput x="357" y="289" width="62" id="txtHeight6"/>
      <mx:TextInput x="580" y="229" width="62" id="txtInitDist" text="0"/>
      <mx:TextInput x="580" y="259" width="62" id="txtOffset" text="100"/>
      <mx:TextInput x="580" y="289" width="62" id="txtFinalDist" text="2000"/>
      <mx:Label x="298" y="97" text="Heat" id="label13"/>
      <mx:Label x="168" y="231" text="Height1" id="label7"/>
      <mx:Label x="168" y="261" text="Height3" id="label4"/>
      <mx:Label x="168" y="291" text="Height5" id="label3"/>
      <mx:Label x="302.5" y="231" text="Height2" id="label8"/>
      <mx:Label x="301" y="261" text="Height4" id="label5"/>
      <mx:Label x="301" y="291" text="Height6" id="label1"/>
      <mx:Label x="484" y="231" text="Initial Distance" id="label9"/>
      <mx:Label x="533" y="261" text="Offset" id="label6"/>
      <mx:Label x="490" y="291" text="Final Distance" id="label2"/>
      <mx:Button x="298.5" y="384" label="Pressure Effects" id="btnOP" click="getOP()"/>
      <mx:Button x="464.5" y="384" label="Thermal Effects" width="142" id="btnThermal"/>
      <mx:Label x="298" y="10" text="Weather Effects" fontWeight="bold" fontSize="18"/>
      </mx:Application>
