0 Replies Latest reply on Aug 8, 2010 11:49 PM by Eli7BBB
    NativeDragDrop into a data-xml tree
    Eli7BBB Level 1
      I am working on an Air app which uses nativeDragDrop.
      BUT
      The target of the drag-drop is not a file system but a tree whose DP is a logical XML (attached as hard-code in the example).
      The problem is that when a dragdrop event occurs, i.e. the user has dragged a file or multiple files from a windows-explorer for example, I can see the source files (in the clipboard) but the app does not know where I stand on the tree.
      The only way I can get around it, is to catch a roll-over event before....but this is not a good solution.
      Attached is my source code: I am looking for the selected item in the tree, or any thing else which can tell me my position.
      Elisheva
      <s:WindowedApplication xmlns:fx="http://ns.adobe.com/mxml/2009"
         xmlns:mx="library://ns.adobe.com/flex/mx"
         xmlns:c="com.everythingFlex.components.*"
         fontFamily="Verdana" fontSize="13"
         width="1200" height="800" xmlns:utils="classes.utils.*"
         initialize="windowedapplication1_initializeHandler(event)"
         creationComplete="windowedapplication1_creationCompleteHandler(event)"
         backgroundColor="#3A558C">
      <s:layout>
      <s:VerticalLayout horizontalAlign="center" paddingTop="10" paddingLeft="10" paddingRight="10" paddingBottom="10" gap="10"/>
      </s:layout>
      <fx:Declarations>
      <mx:Fade id="fadeIn" alphaFrom="0" alphaTo="1" duration="1000"/>
      <mx:Fade id="fadeOut" alphaFrom="1" alphaTo="0" duration="1000"/>
      </fx:Declarations>
      <fx:Script>
      <![CDATA[
      import classes.utils.DisplayUtils;
      import classes.utils.UserUtils;
      import com.everythingFlex.components.ImageToolTip;
      import flash.desktop.NativeDragManager;
      import mx.charts.chartClasses.DataDescription;
      import mx.collections.ArrayCollection;
      import mx.collections.XMLListCollection;
      import mx.controls.Alert;
      import mx.controls.FileSystemDataGrid;
      import mx.controls.Image;
      import mx.controls.Menu;
      import mx.controls.ToolTip;
      import mx.controls.Tree;
      import mx.controls.dataGridClasses.DataGridItemRenderer;
      import mx.controls.treeClasses.DefaultDataDescriptor;
      import mx.core.DragSource;
      import mx.core.UIComponent;
      import mx.events.CloseEvent;
      import mx.events.DragEvent;
      import mx.events.FlexEvent;
      import mx.events.IndexChangedEvent;
      import mx.events.ListEvent;
      import mx.events.ToolTipEvent;
      import mx.events.ValidationResultEvent;
      import mx.managers.DragManager;
      import mx.managers.ToolTipManager;
      import mx.styles.StyleManager;
      import spark.components.List;
      import spark.components.supportClasses.ListBase;
      import spark.events.RendererExistenceEvent;
      import spark.layouts.supportClasses.DropLocation;
      import spark.skins.spark.BorderContainerSkin;
      import spark.skins.spark.WindowedApplicationSkin;
      [Bindable] public var mTreeDataXML:XML=
      <tree>
      <Backgrounds label="Backgrounds">
        <HappyStickers label="HappyStickers">
      <item asset_name="2009_0414april_09_tennis0012.JPG" location="C:\Documents and Settings\User\My Documents\game_111" asset_location="C:\Documents and Settings\User\My Documents\game_111\Backgrounds" tags="1"/>
      <item asset_name="choose_location.png" location="C:\Documents and Settings\User\My Documents\game_111" asset_location="C:\Documents and Settings\User\My Documents\game_111\Backgrounds" tags="1"/>
        </HappyStickers>
      </Backgrounds>
      <Stickers label="Stickers">
      <item asset_name="3d_friends_list_in_facebook.png" location="C:\Documents and Settings\User\My Documents\game_111" asset_location="C:\Documents and Settings\User\My Documents\game_111\Stickers" tags="1"/>
        </HappyStickers>
      </Stickers>
      <Masks label="Masks"/>
      <Models label="Models"/>
      <Pics label="Pics"/>
        </tree>;;
      private var _mCurrentRollOverLocation:String;
      public function createClipboard( sourceFile:File):Clipboard {
      var transfer:Clipboard = new Clipboard();
      transfer.setData(ClipboardFormats.FILE_LIST_FORMAT,
      new Array(sourceFile),
      false);
      // Standard file list format
      return transfer;
      public function logMsg(log_str:String):void {
      logger.text += log_str + "\n";
      private function get mCurrentRollOverLocation():String {
      return (_mCurrentRollOverLocation);
      private function set mCurrentRollOverLocation(value:String):void {
      _mCurrentRollOverLocation = value;
      protected function windowedapplication1_creationCompleteHandler(event:FlexEvent):void {
      DragManager.isDragging;
      protected function windowedapplication1_initializeHandler(event:FlexEvent):void {
      ToolTipManager.showEffect = fadeIn;
      ToolTipManager.hideEffect = fadeOut;
      protected function dataTree_dragEnterHandler(event:DragEvent):void
      //logMsg("dataTree_dragEnterHandler");
      DragManager.acceptDragDrop(UIComponent(event.currentTarget));
      protected function dataTree_itemRollOverHandler(event:ListEvent):void {
      // get the file full path from the xml
      var item:XML = event.itemRenderer.data as XML;
      mCurrentRollOverLocation = item.localName();
      //logMsg("dataTree_itemRollOverHandler "+item.localName());
      // I show tooltips only for items
      if (item.localName() == "item") {
      event.target.toolTip = null;
      var itemX:int = event.itemRenderer.x;
      var itemY:int = event.itemRenderer.y;
      var point:Point = event.currentTarget.contentToGlobal(new Point(itemX,itemY));
      event.target.toolTip =  String(item.@asset_location).concat("\\",item.@asset_name);
      ToolTipManager.currentToolTip.move(point.x + event.itemRenderer.width/2 , point.y - ToolTipManager.currentToolTip.height);
      protected function dataTree_itemRollOutHandler(event:ListEvent):void
      mCurrentRollOverLocation = null;
      if (event.target.toolTip != null) {
      protected function dataGrids_mouseDownHandler(event:MouseEvent):void {
      var fs:FileSystemDataGrid =FileSystemDataGrid(event.currentTarget);
      logMsg("dataGrids_mouseDownHandler "+(fs.selectedItem as File).nativePath);
      if (fs.selectedItem.isDirectory == true) {
      return;
      if (fs.selectedItem != null) {
      var transferObject:Clipboard = createClipboard(fs.selectedItem as File);
      NativeDragManager.doDrag(InteractiveObject(event.target),
      transferObject,
      null,
      new Point(0,0));
      protected function sourceFileSystem_nativeDragEnterHandler(event:NativeDragEvent):void {
      NativeDragManager.dropAction = NativeDragActions.COPY;
      if(event.clipboard.hasFormat(ClipboardFormats.FILE_LIST_FORMAT)){
      NativeDragManager.acceptDragDrop(InteractiveObject(event.currentTarget)); //'this' is the receiving component
      protected function dataTree_nativeDragEnterHandler(event:NativeDragEvent):void
      private function onIOError(event:IOErrorEvent):void {
      logMsg("onIOError " + event.text);
      protected function dataTree_nativeDragDropHandler(event:NativeDragEvent):void
      // list of files to copy
      logMsg("dataTree_nativeDragDropHandler");
      var dropObj:Object = (event.target as Tree).selectedItem;
      if (dropObj) {
      logMsg("dataTree_nativeDragDropHandler dropObj " + dropObj);
      event.preventDefault();
      var files:Array = event.clipboard.getData(ClipboardFormats.FILE_LIST_FORMAT, ClipboardTransferMode.ORIGINAL_PREFERRED) as Array;
      // get where I am from the rollover event
      var aCopyToLocation:String = mCurrentRollOverLocation;
      if (aCopyToLocation == null) {
      aCopyToLocation = "Backgrounds";
      private function onComplete(event:Event):void {
      protected function dataTree_mouseUpHandler(event:MouseEvent):void
      // TODO Auto-generated method stub
      protected function treeItemClickHandler(event:ListEvent):void {
      // show the image in the image container
      //var aAssetname:String = String(event.itemRenderer.data);
      var aCurrentClickedFileName:String = String(item.@asset_location).concat("\\",item.@asset_name);
      logMsg("Loading "+aCurrentClickedFileName);
      private function treeLabelFunction(item:XML):String {
      var k:String = item.@asset_name;
      return (k);
      //item.@asset_name) as String;
      var t:String = item.@label;
      return t;//item.@label as String;
      protected function dataTree_changeHandler(event:ListEvent):void
      logMsg("dataTree_changeHandler ");
      </fx:Script>
      <mx:Tree id="dataTree" itemClick="treeItemClickHandler(event)" verticalScrollPolicy="auto"
      dataProvider="{mTreeDataXML.children()}"
      horizontalScrollPolicy="auto" paddingLeft="10" paddingRight="10"
      showRoot="false"
      change="dataTree_changeHandler(event)" width="100%" height="100%"
      itemRollOver="dataTree_itemRollOverHandler(event)" itemRollOut="dataTree_itemRollOutHandler(event)"
      mouseUp="dataTree_mouseUpHandler(event)"
      labelFunction="treeLabelFunction"
      nativeDragEnter="dataTree_nativeDragEnterHandler(event)"
      nativeDragDrop="dataTree_nativeDragDropHandler(event)"
      <s:TextArea verticalScrollPolicy="auto" id="logger" width="450" height="200" borderVisible="true" alpha=".5"
      paddingTop="10" paddingLeft="10" paddingRight="10" paddingBottom="10"/>
      <s:Button label="clear" click="{logger.text=''}"/>
      </s:WindowedApplication>
