5 Replies Latest reply on Aug 12, 2010 9:47 PM by samschauhan
    Reading Webservice Result
    samschauhan Level 1
      I am getting a webservice result as:
      "<StockQuotes><Stock><Symbol>ABC</Symbol><Last>20.24</Last><Date>8/6/2010</Date><Time>4:00pm</Time><Change>0.00</Change><Open>N/A</Open><High>N/A</H igh><Low>N/A</Low><Volume>0</Volume><MktCap>41.563B</MktCap><PreviousClose>20.24</Previous Close><PercentageChange>0.00%</PercentageChange><AnnRange>14.72 - 20.97</AnnRange><Earns>0.706</Earns><P-E>28.67</P-E><Name>ABC Corporation C</Name></Stock></StockQuotes>"
      This is stored in the event.result property in the ResultHandler .
      How can I parse this response and read, say, Last tag?
      event.result.Last gives an error.
      SAM
        • 1. Re: Reading Webservice Result
          Balakrishnan V Level 3
          Store this event.result into an XML type object.
          Ex:
          var resultXML:XML=new XML()
          resutlXML = event.result as XML
          //To read Last, use
          resultXML.Stock.Last
          For more details, look up
          http://wso2.org/project/mashup/0.2/docs/e4xquickstart.html (OR)
          http://www.trilemetry.com/clients/f3gse/partIII/partIIIa/workingWithData_e4x.cfm#
          [They are simple E4X tutorials]
          Hope this helps
          Balakrishnan V
          • 2. Re: Reading Webservice Result
            samschauhan Level 1
            Thanks for your reply, but I am afraid it still didnt work.
            Here is my complete code:
            <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml"
                            layout="absolute">
                <mx:WebService id="userRequest"
                               wsdl="http://www.webservicex.net/stockquote.asmx?wsdl"
                               result="resultHandler(event)">
                </mx:WebService>
                <mx:Script>
                    <![CDATA[
                        import mx.utils.XMLUtil;
                        import mx.rpc.events.ResultEvent;
                        private function resultHandler(event:ResultEvent):void
                            var resultXML:XML=new XML();
                            resultXML=event.result as XML;
                            trace(resultXML.Stock.Last);
                            display = resultXML.Stock.Last;
                        private function clickHandler():void
                            var stock:String = new String();
                            stock = input.text;
                            userRequest.GetQuote(stock);
                </mx:Script>
                <mx:Label id="enter"
                          x="41"
                          y="40"
                          text="Enter Symbol:"
                          width="88"
                          height="25"
                          textAlign="left"/>
                <mx:Button x="325"
                           y="38"
                           label="Get Quote"
                           click="clickHandler()"/>
                <mx:Label id="display"
                          x="41"
                          y="98"
                          text="N/A"
                          width="160"
                          height="28"/>
                <mx:TextInput id="input" x="137" y="38"/>
                </mx:Application>
            • 3. Re: Reading Webservice Result
              I'm sorry. You need to give resultXML=new XML(event.result).
              Btw, also change the "display" to "display.text"
              With this, it works. I tried it out.
              Balakrishnan V
              • 4. Re: Reading Webservice Result
                BhaskerChari Level 4
                Replace your resultHandler() function with the below one...
                                resultXML = new XML(event.result as String);
                               if(resultXML != null && resultXML.hasOwnProperty("Stock"))
                                    display.text = resultXML.Stock.Last;
                Bhasker Chari
                • 5. Re: Reading Webservice Result
                  samschauhan Level 1
                  Bhasker/Bala,
                  Thanks for your quick help. It worked!
                  SAM
