2 Replies Latest reply on Aug 9, 2010 1:44 PM by Flex harUI
    Selectable <mx:Label> background color property
    pzzzza
      How can I change background color of selected text in my mx:Label when selectable=true.  Default color is blue.
      thanks in advance
        • 1. Re: Selectable <mx:Label> background color property
          ShardulSingh Level 3
          I think you should use something else for this use instead of Label.That will be better.
          But if you want to do this with Label only then the solution is as below.
          Create you own Label class which extends Label class of flex.And then use as I hv used it in my application.Below is the source
          code for both.
          CustomLabel.as
          package
              import mx.controls.Label;
              public class CustomLabel extends Label
                  public function CustomLabel()
                      super();
                  public function getTxt() : *
                      return textField;
          MainApplication
          <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml"
                  layout="vertical"
                  xmlns:local="*">
              <mx:Script>
                  <![CDATA[
                      private function onCreationComplete():void
                          customLabel.getTxt().background = true;
                          customLabel.getTxt().backgroundColor = '0xFFFF00';
              </mx:Script>
              <local:CustomLabel id="customLabel" text="Hello world" selectable="true" creationComplete="onCreationComplete()"/>
          </mx:Application>
          Let me know if u hv any issue.
          with Regards,
          Shardul Singh Bartwal
          • 2. Re: Selectable <mx:Label> background color property
            Flex harUI Adobe Employee
            You can't change the selection color in mx:Label.
