10 Replies Latest reply: Aug 10, 2010 11:48 AM by craneium RSS
    How do I use an itemrenderer with array from actionscript???
    craneium Community Member
      I am wanting to populating a list control with several Checkbox controls, i understand how to use the itemrenderer but all the examples I have found populate the dataprovider array outside of actionscript i want to know how to create my array inside of action script and pass it to the listbox. when i was playing around with this i could get the listbox to populate with checkbox but it would not so the label of the items, i am guessing i was not passing the right information in the array.
        • 1. Re: How do I use an itemrenderer with array from actionscript???
          Flex harUI Adobe Employee
          Var arr:Array = [];
              arr.push();
              var al:ArrayList = new ArrayList(arr);
              list.dataProvider = al;
          • 2. Re: How do I use an itemrenderer with array from actionscript???
            yeah thats what i thought but the label propority of the check box is not getting populated. the checkboxes come in but without a label on thim.
            • 3. Re: How do I use an itemrenderer with array from actionscript???
              BhaskerChari Community Member
              Hi craneium,
              In your itemRenderer file you need to specify the property to bind fromm your dataprovider which is stored in data object for each itemRenderer...
              <mx:CheckBox id="chk" label="{data.label}" />
              Here label is one of the property that you have in your dataprovider for each object...you can replace data.label with the text property you want to be displayed..
              I Hope  you got my point...
              If this post answers your question or helps, please kindly mark it as such.
              Bhasker Chari
              • 4. Re: How do I use an itemrenderer with array from actionscript???
                i am still a little confused here is what i have at current state, which is not
                working
                <fx:Script>
                        <![CDATA[
                            public var myarray:ArrayList;
                            public var returnedarray:Array = ["a","b","c","d","e","f","g","h"];
                            public var key:String = "label"
                            public function init():void{
                                myarray = new ArrayList;
                                for (var i:int = 0; i<=(returnedarray.length-1); i++){
                                    var myobj:Object = {};
                                    myobj[key] = returnedarray[i].toString();
                                    myarray.addItem(myobj);
                                FileList.dataProvider = myarray;
                    </fx:Script>
                <s:List id="FileList" x="10" y="99" width="207" height="285" color="#000000" contentBackgroundColor="#FFFFFF" alternatingItemColors="[#ffffff,#eadee0]" borderVisible="true">
                                    <s:itemRenderer>
                                        <fx:Component>
                                            <s:CheckBox label="{myarray.label}"/>
                                        </fx:Component>
                                    </s:itemRenderer>
                                </s:List>
                this throughs a unkown item error (myarray)
                • 5. Re: How do I use an itemrenderer with array from actionscript???
                  MarkTaylor46 Community Member
                  Use data.label not myarray.label.  Data is passed to an item renderer via data object (which in turn gets sourced from your dataprovider - in your case myarray).
                  regards,
                  Mark.
                  • 6. Re: How do I use an itemrenderer with array from actionscript???
                    I am still getting and error (1120: Access of undefined property; data.)
                                        <s:itemRenderer>
                                            <fx:Component>
                                                <s:CheckBox label="{data.label}"/>
                                            </fx:Component>
                                        </s:itemRenderer>
                    • 7. Re: How do I use an itemrenderer with array from actionscript???
                      your s: list has no dataProvider  you need to add one. I think that's why.
                      Regards, Mark.
                      oops - just noticed ur doing it in actionscript instead of mxml. i presume your init function is invoked on creationcomplete event? try adding a breakpoint in the item renderer and see what it being passed in.
                      • 8. Re: How do I use an itemrenderer with array from actionscript???
                        man this cannot be this hard, still error 1120.
                        <fx:Declarations>
                                <!-- Place non-visual elements (e.g., services, value objects) here -->
                                <s:ArrayList id="myarray">
                                    <fx:Object label="File Items Here"/>
                                </s:ArrayList>
                        </fx:Declarations>
                        <s:List id="FileList" dataProvider="{myarray}" x="10" y="99" width="207" height="285" >
                             <s:itemRenderer>
                                  <fx:Component>
                                  </fx:Component>
                             </s:itemRenderer>
                        </s:List>
                        • 9. Re: How do I use an itemrenderer with array from actionscript???
                          change your code as shown below and it works. Use an external renderer instead of an inline one.
                          <s:WindowedApplication xmlns:fx="http://ns.adobe.com/mxml/2009"
                                                 xmlns:mx="library://ns.adobe.com/flex/mx"
                                                 creationComplete="init()">
                              <fx:Declarations>
                              </fx:Declarations>
                              <fx:Script>
                                  <![CDATA[
                                      import mx.collections.ArrayList;
                                          myarray = new ArrayList();
                              </fx:Script>
                              <s:List id="FileList" x="10" y="99" width="207" height="285" color="#000000" contentBackgroundColor="#FFFFFF" alternatingItemColors="[#ffffff,#eadee0]" borderVisible="true" itemRenderer="myItemRenderer">
                              </s:List>
                          </s:WindowedApplication>
                          then create "myItemRenderer" in the same folder....
                          <s:ItemRenderer xmlns:fx="http://ns.adobe.com/mxml/2009"
                                          autoDrawBackground="true">
                          </s:ItemRenderer>
                          I hope this is what you were expecting.
                          Regards,
                          Mark.
                          • 10. Re: How do I use an itemrenderer with array from actionscript???
                            thank you, thats right on.
