2 Replies Latest reply on Aug 9, 2010 1:15 PM by Amarelv
    Project conversion (upgrade) RH7 to RH8 Problems
    tojo45
      Using RH8 / Windows XP;
      Four projects, by same writer, converted to RH8 from 7.
      3 of the projects had a similar issue, which I am posting about.
      Using a Master Topic on all 3 projects.
      After the conversion, viewing a topic in design mode the header appears empty, and very large, no text. Fills the screen.  Need to scroll down to see the topic text.
      Also, the TOC was gone in two of the three projects.
      I have inserted a topic HTML at the end of this posting  from two of the projects in case that helps.
      One is a french translation and has a lot of XML tags regarding the language. I'm not sure where that even comes from.  The other is in English and has just the normal XML tags in the "head".
      Both projects have the same issue with the huge, blank header on the Design page.  But compiled they look normal except as noted below.
      In the compiled Help the topic named "PAC Config" shows no border AND no background color.  All topics are the same.
      In the compiled Help the topic named "French PAC" shows no border in the Header/Banner, but does have the background color.  All topics are the same.
      I'm at a loss, and not really sure what else to include.  Any help would be greatly appreciated.
      Regards
      Joe
      PAC CONFIG
      <?xml version="1.0" encoding="utf-8" ?>
      <!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
      <html xmlns="http://www.w3.org/1999/xhtml">
      <head>
      <meta http-equiv="Content-Type" content="text/html; charset=utf-8" />
      <meta name="template" content="PAC Configuration 4.0.htt" />
      <meta name="topic-status" content="Ready for Review" />
      <meta name="generator" content="Adobe RoboHelp 8" />
      <title>An Overview of the PAC Configuration Process</title>
      <link rel="StyleSheet" href="../default.css" type="text/css" />
      </head>
      <body>
      <?rh-placeholder type="header" ?>
      <h1>An Overview of the PAC Configuration Process</h1>
      <p style="font-weight: bold;">The Configuration File</p>
      <p>&#160;</p>
      <p>Library<span style="color: #ff0000;">•</span><span style="font-weight: bold;">Solution</span>
      PAC lets you create a number of different sets of PAC display pages to
      suit your needs. &#160;Each set of pages has a configuration file that
      stores all the information about that set of pages – the content of each
      page, the variables used, the way lists are displayed, and more. &#160;For
      example, you could create customized configurations to have General, Reference,
      and Children's displays within the same library, or Main, South Branch,
      and North Branch display for a library system. &#160;Any number of combinations
      are possible.</p>
      <p style="font-weight: normal;">&#160;</p>
      <p style="font-weight: bold;">The Display Pages</p>
      <p>&#160;</p>
      PAC Configuration Utility</span> contains many display pages that are
      generated by the parameters set in a PAC Configuration file. &#160;You
      can edit many of the display parameters through the PAC Configuration
      program. &#160;If you have expertise with HTML and JavaScript, you can
      also use an HTML Editor and edit the contents of the display pages to
      create HTML pages that can supplement or replace the existing display
      pages. &#160;The <span style="font-weight: bold;">PAC Configuration Utility</span>
      program also lets you create user-defined HTML pages.</p>
      <p>&#160;</p>
      <p>The table below shows the <span style="font-weight: bold;">PAC Configuration
      Parameters</span> expanded menus:</p>
      <p>&#160;</p>
      <p><img src="../PAC Config Parameters menu chart.gif" alt="" style="border: none;"
                              width="644" height="494" border="0" /></p>
      <p>&#160;</p>
      <p>&#160;&#160;&#160;<span style="font-weight: bold;">PAC Configuration
      Parameters</span> (continued)</p>
      <p>&#160;</p>
      <p><img src="../PAC Config Parameters menu chart 2.gif" alt="" style="border: none;"
                              width="643" height="341" border="0" /></p>
      <p>&#160;</p>
      <?rh-placeholder type="footer" ?>
      </body>
      </html>
      FRENCH PAC
      <head>
      <meta name="Originator" content="ImportDoc" />
      <meta name="OriginalFile" content="PAC_4.0_Help_FRENCH.doc" />
      <meta name="template" content="PAC 4.0 Aide.htt" />
      <title>Bienvenue</title>
      <link rel="stylesheet" href="../PAC_4.0_Help_FRENCH.css" type="text/css" />
      <style type="text/css">/*<![CDATA[*/
      A:visited {
                  color: #0000ff;
      A:link {
                  color: #0000ff;
      /*]]>*/</style>
      </head>
      <body lang="EN-US" xml:lang="EN-US">
      <div>
                  <h1><span lang="FR" xml:lang="FR">Bienvenue</span></h1>
                  <p style="margin-top: 6.0pt; margin-right: 0in; margin-bottom: 6.0pt;
                              margin-left: 0in;"><span lang="FR" xml:lang="FR">Bienvenue dans
                  le catalogue public en ligne (PAC) de votre bibliothèque.</span> <span
                  lang="FR" xml:lang="FR">Le catalogue PAC vous aidera à trouver ce
                  que vous cherchez dans votre bibliothèque, sans qu’il soit nécessaire
                  de vous rendre dans toutes les allées où VOUS croyez pouvoir trouver
                  les ouvrages qui vous intéressent.</span> <span lang="FR" xml:lang="FR">Le
                  catalogue PAC vous indique si l’article qui vous intéresse est disponible
                  ou mis de côté.</span> <span lang="FR" xml:lang="FR">Il vous permet
                  également de modifier vos renseignements d’abonné, comme votre numéro
                  de téléphone ou votre adresse électronique.</span> <span lang="FR"
                  xml:lang="FR">Vous pouvez aussi vérifier vos amendes et imprimer un
                  historique de vos prêts.</span></p>
                              margin-left: 0in;"><span lang="FR" xml:lang="FR">Il est plus facile
                  d’effectuer une recherche lorsque vous disposez de certaines informations,
                  comme un titre ou un nom d’auteur, mais même sans aucune information
                  précise de départ, vous pouvez trouver ce que vous chercher.</span>
                  <span lang="FR" xml:lang="FR">Lorsque vous avez inscrit ce que vous
                  cherchez, vous recevez une série de résultats et des informations
                  sur votre recherche.</span> <span lang="FR" xml:lang="FR">Si vous
                  ne trouvez pas exactement ce que vous cherchez lors de votre première
                  tentative, vous pouvez modifier vos critères de recherche et essayer
                  de nouveau.</span></p>
                              margin-left: 0in;"><b style="font-weight: bold;"><span lang="FR"
                  xml:lang="FR">Comment fonctionne le système?</span></b></p>
                              margin-left: 0in;"><span lang="FR" xml:lang="FR">Vous êtes-vous
                  déjà demandé d’où venaient les résultats obtenus d’une recherche?</span>
                  <span lang="FR" xml:lang="FR">Les informations disponibles dans le
                  catalogue PAC sont regroupées dans ce que nous appelons des fiches
                  MARC.</span> <span lang="FR" xml:lang="FR">Une fiche MARC se compose
                  de plusieurs champs.</span> <span lang="FR" xml:lang="FR">Tout d’abord,
                  on y retrouve un champ indiquant le titre de l’article, peu importe
                  qu’il s’agisse d’un livre, d’un DVD, d’un CD ou autre.</span> <span
                  lang="FR" xml:lang="FR">La fiche contient également des champs d’auteur,
                  d’éditeur, d’illustrateur, de sujet et de remarques concernant l’article.</span>
                  <span lang="FR" xml:lang="FR">Tous ces champs forment une fiche MARC
                  et les informations qu’ils contiennent sont traitées par le programme
                  du catalogue PAC pour vous transmettre les résultats désignant des
                  articles de votre bibliothèque.</span> <span lang="FR" xml:lang="FR">Vous
                  pouvez remercier vos bibliothécaires.</span> <span lang="FR" xml:lang="FR">C’est
                  grâce à leur travail constant que le catalogue PAC vous est offert.</span>
                  &#160;</p>
                              margin-left: 0in;"><span lang="FR" xml:lang="FR">Maintenant que
                  vous savez de quoi il s’agit, nous pouvons commencer.</span></p>
                  xml:lang="FR">Premier pas</span></b></p>
                              margin-left: 0in;"><span lang="FR" xml:lang="FR">La première chose
                  que vous devez comprendre est comment naviguer dans le module d’aide.
                  Il a été conçu pour vous aider à exécuter les tâches les plus simples
                  et les recherches les plus complexes. Il vous indique également comment
                  accéder à votre dossier d'abonné afin que vous</span> <span lang="FR"
                  xml:lang="FR" style="font-family: Arial, sans-serif;">puissiez vous
                  aider vous‑même. Pour savoir comment circuler dans le catalogue PAC,
                  reportez-vous à</span> <span class="Hyperlink" lang="FR" xml:lang="FR"><a
                  href="Naviguer_dans_le_PAC.htm" style="font-family: Arial, sans-serif;">Naviguer
                  dans le PAC</a></span><span lang="FR" xml:lang="FR" style="font-family: Arial, sans-serif;">.
                  Si vous savez déjà comment circuler dans le PAC, passez directement
                  à</span> <span class="Hyperlink" lang="FR" xml:lang="FR"><a href="../Options_de_recherche/Aperçu_des_proc_dures_de_recherche.htm"
                  style="font-family: Arial, sans-serif;">Aperçu des procédures de recherche</a></span>
                  <span lang="FR" xml:lang="FR" style="font-family: Arial, sans-serif;">et
                  trouvez votre livre sans plus perdre de temps!</span></p>
                              margin-left: 0in; font-family: Arial, sans-serif;"><span lang="FR"
                  xml:lang="FR">Si vous désirez obtenir des informations supplémentaires
                  sur la façon de circuler dans le catalogue PAC, reportez-vous à</span>
                  <span class="Hyperlink" lang="FR" xml:lang="FR"><a href="../Barre_d%27outils_PAC/Aperçu_de_la_barre_d’outils_PAC.htm"
                  de la barre d’outils PAC</a></span><span lang="FR" xml:lang="FR">.</span></p>
      </div>
      <span style="font-size: 12.0pt; font-family: 'Times New Roman'; layout-grid-mode: line;"><br
                  style="clear: all;" clear="all" />
      </span>
      </body>
      </html>
