2 Replies Latest reply on Aug 9, 2010 5:50 PM by ssardar
    Creating AdvancedDataGrid in AS
    ssardar
      ok I'll try to make this clear as possible.
      I've decided to create my AdvancedDataGrid in Actionscript becuase the users want to be able to create columns dynamically.
      My service returns a ListCollectionView of object proxies.
      Which I then cast into an ArrayCollection of Objects.
      private var myADG:AdvancedDataGrid = new AdvancedDataGrid;
      private function generateGrid():void
      var clms:Array;
      myADG.dataProvider=gridData;
      myADG.percentWidth=100;
      myADG.percentHeight=100;
      myADG.visible=
      true;
      myADG.x=0;
      myADG.y=0;
      myADG.designViewDataType=
      "flat";
      myADG.horizontalScrollPolicy=
      "on";
      myADG.verticalScrollPolicy=
      "on";
      myADG.lockedColumnCount=6;
      myADG.sortExpertMode=
      true;
      myADG.headerWordWrap=
      true;
      clms = myADG.columns;
      //loop to add columns
      var adgc:AdvancedDataGridColumn = new AdvancedDataGridColumn();
      adgc.headerText=
      "Sales Order"
      adgc.dataField=myADG.dataProvider.pdNO;   <-----I have no idea what should be, pdNO is a variable from the list of objects that are returned.
      adgc.width=72
      adgc.visible=
      true;
      clms.push(adgc);
      //end loop
      myADG.columns=clms;
      pan1.addChild(myADG);
      I'm a little unclear how to capture the columns from the existing data set (I am just trying to build the grid as is, none of the dynamic stuff yet).
      I had this all in MXML before and it was fairly easy to bind the dataField based on each Object property.  But how do I do that now, yes i know it needs to be a loop through an array, but I was just trying to add one column for now to see if I can get it to work.
      Thanks in advance, I hope that's clear.
