7 Replies Latest reply on Aug 10, 2010 7:37 PM by kglad
    comparing Array
    JaxNa
      Hello,
      can you plz help me.
      i am checking two array.
      var temItemNo_array:Array = Array(12,13,17,19,20);
      var Item_array:Array = Array(12, 13, 14, 15, 16, 17);
      when checked [B]temItemNo[/B] &&  [B]Item_array[/B] in this arrays 12,13 are same no.
      but when 12 & 13 got continuous common no. that time want stop on 13 no and add on 13+1=14
      JaxNa
        • 1. Re: comparing Array
          what?
          • 2. Re: comparing Array
            JaxNa Level 1
            here are my two array.
            when i compare this array that time i got common no.(12,13,17).
            12 and 13 is continuous no.
            when compare array and i got 12, 13 that time it should be stop this compare and that time i want  next no that is (14)
            Thanks in Advance
            • 3. Re: comparing Array
              ok.  i understand you're looking for common elements in 2 arrays.  i understand you want to check if any common elements are adjacent integers.
              if there are 2 common elements that are adjacent integers you want to search for the smallest integer greater than the 2 adjacent ones?  does that search have anything to do with elements in either array?
              • 4. Re: comparing Array
                JaxNa Level 1
                if there are 2 common elements that are adjacent integers then i want next integer
                if 12 & 13 are 2 common element that are adjacent then i want next integer is 14.
                one more example
                if 17& 18 then i want  next integer is 19.
                Thanks a lot kglad
                • 5. Re: comparing Array
                  if both arrays contain integers you can use the following function to return an array that meets your criteria:
                  function findAdjacentIntegers(a1:Array,a2:Array):Array{
                      var returnA:Array = [];
                      var t1:Array = a1.slice();
                      var t2:Array = a2.slice();
                      t1.sort(18).reverse();
                      t2.sort(18).reverse();
                      for(var i=0;i<t1.length;i++){
                          for(var j=0;j<t2.length;j++){
                              if(t1[i]==t2[j]){
                                  if(t1[i+1]==t1[i]+1 && t1[i+1]==t2[j+1]){
                                      returnA.push(t1[i]+2);
                      return returnA;
                  • 6. Re: comparing Array
                    JaxNa Level 1
                    hey thanks a lot
                    can you give me one more ans plz??
                    var temItemNo_array:Array = Array(11,14,15,19,20);
                    temItemNo_array in this array first integer is not common so that loop should be the break.
                    how can do this?
                    Thank dear
                    • 7. Re: comparing Array
                      with your criteria to search for adjacent integers common to both arrays, passing both those arrays to the function i suggested should return 16.
                      p.s.  please mark this thread as answered.
