1 Reply Latest reply on Aug 11, 2010 2:36 AM by Didier Bolf
    select several cells on the same row of an OLAPDataGrid
    Didier Bolf
      hello
      I have:
      var odg:OLAPDataGrid = new OLAPDataGrid()
      odg.selectionMode = "multipleCells";
      when I try to select programmatically  several cells on the same row, for example :
           odg.selectedCells = [{rowIndex: 1, columnIndex: 2}, {rowIndex: 1, columnIndex: 4}];
           odg.validateNow();
      it works, the both cells are selected. but then I cannot unselect the second cell anymore (by clicking a cell in the grid)
      the problem occurs when I try to select two cells of the same row at the same time using selectedCells setter.
      when the cells are not on the same row, it works
      thanks for your help
      best regards
      Didier
        • 1. Re: select several cells on the same row of an OLAPDataGrid
          Didier Bolf Level 1
          in fact I wanted to select cells by row or column (I believe this is not supported with the olapdatagrid)
          I found something that seems working ...
          package
              import mx.controls.OLAPDataGrid;
              import mx.controls.listClasses.IListItemRenderer;
              public class OLAPDataGridEx extends OLAPDataGrid {
                  public function selectRow(rowIndex:int, firstColumnIndex:int, lastColumnIndex:int):void {
                      var visibleCoords:Object = absoluteToVisibleIndices(rowIndex,firstColumnIndex);
                      var listItem:IListItemRenderer = listItems[visibleCoords.rowIndex][visibleCoords.columnIndex];
                      selectCellItem(listItem, false, false);
                      visibleCoords = absoluteToVisibleIndices(rowIndex, lastColumnIndex);
                      selectCellItem(listItem, true, false);
                      validateNow();
                  public function selectColumn(columnIndex:int, firstRowIndex:int, lastRowIndex:int):void {
                      var visibleCoords:Object = absoluteToVisibleIndices(firstRowIndex, columnIndex);
                      visibleCoords = absoluteToVisibleIndices(lastRowIndex, columnIndex);
                      validateNow();
          bye
          didier
