2 Replies Latest reply on Aug 11, 2010 4:42 AM by PJSB_DK
    Lost all my works! Flash File Corrupt!
    adishaswot
      For whole damn month i spend writing script for a actionscript application on Flash CS5. i had my Window$ Crashed!! and when  i tried opening the flash file, it says"error opening File!". my swf is sized  0 KB,  I even bought a decompiler, Trillix Flash Decompiler and tried to decompile the swf, it says swf corrupt. now all i have is some classes and external swfs. those thousands of as3 codes inside the fla file and the library objects are all gone. i am so fustrated this moment. Please CAN I EXPECT SOME HELP?????
        • 1. Re: Lost all my works! Flash File Corrupt!
          gwenn_guihal
          Flash CS5 is very very unstable.It sucks ! Don't install it !
          • 2. Re: Lost all my works! Flash File Corrupt!
            PJSB_DK Level 3
            Hi.
            I certainly feel for you.
            I would advice you to always keep a backup of your work.
            As for the stability of CS5, I have not experienced any of your
            problems. I haven't had a single crash or corrupted files and everything has been
            working flawlessly since installation. (I might be a lucky sob?? ).
            The only system crash (system lockups) I've experienced were due to:
            A: Some obscure internet app installed without consent. (IExplorer related)...
            B: Driver related problem...(Game security issues or obsolete software drivers).
            C: Lightning/poweroutage..
            My advice to you is:
            1. Keep you machine as clea as possible..
            2. Divide your harddrive into at least two partitions.
                One for the operating system and standard software and
                one for your data . If your C drive goes fubar, it won't hurt
                your data section, even if you have to reformat and reinstall.
            3. Keep your drivers up to date.
            4. Don't install anything you won't miss.
            If your machine goes fubar, then try to do a system restore. It won't
            restore your corrupt code, though. Corrupt is corrupt...Nothing to do
            about that, I'm sorry to say.
            I can't stress it enough...ALWAYS keep a backup of your work. I always
            keep several versions of every project I've done. It doesn't take much
            time to copy your work into a different location/folder or burn your work onto a CD/DVD.
            Anyway: I sincerely hope you solve your problem
            Best of luck
            Peter
