0 Replies Latest reply on Aug 10, 2010 9:30 AM by guyoha
    when creating new table in sqllite db via Flex it become encoded as "utf-16le"
    guyoha
      Hi Guys
      I have some annoying problem with my AIR application
      The application is communicating with a local DB (sqllite).
      as part of initial installation I'm checking if the db exist.
      in case not then:
      1. I create one (file)
      2. create the relevent tables inside
      3. and populate them.
      For some reason, on the tables creation step the sqllite db become encoded as UTF-16le instead of UTF-8.
      The question is how can I make the tables creation step to leave the db as UTF-8
      thanks in advance for your help.
      This is my creation code
      1. the "connection" is from flash.data.SQLConnection type
      2. The "file" contain the following information
        <sql>
        <statement>
        CREATE TABLE IF NOT EXISTS MYTABLE
              MYTABLE_VERSION                NUMBER NOT NULL,
               MYTA|BLE_INSERT_DATE                 DATE NOT NULL
        </statement>
        </sql>
      3. The below is the relevent code:
      var stream:FileStream = new FileStream();
                  stream.open(file, FileMode.READ);
                  var xml:XML = XML(stream.readUTFBytes(stream.bytesAvailable));
                  stream.close();
                  var statement:XML = null;
                  try
                      connection.begin(lockType);
                      for each (statement in xml.statement)
                          var stmt:SQLStatement = new SQLStatement();
                          stmt.sqlConnection = connection;
                          stmt.text = statement;
                          stmt.execute();
                  } catch(err:Error)
                      connection.rollback();
                      throw err;
                  connection.commit();
