4 Replies Latest reply on Aug 31, 2010 12:19 AM by remoteitservices
    test stratus availability
    zafer76
      hi,
      i use stratus for my game project. it works about %70 of computers which i tested.
      how can i test stratus like http://cc.rtmfp.net with as3 at runtime. i install a red5. if a client can not use status it will connect form red5 server. if user sets server manually it works but i want an automatic solution
      thanks...
        • 1. Re: test stratus availability
          remoteitservices Level 1
          I have the exact same problem. I've got the infrastructure to switch between RTMFP and streaming trough FMS, but I've no real method of detecting when RTMFP is not available. I can connect to the Stratus servers on some clients, but the actual UDP connection between the clients won't work. Now I know what ports RTMFP requires, but how can I test if these ports are available. Testing wether connecting to the Stratus server works is not reliable, since the actual connection uses random UDP ports from 1000 and up. Is there any way to test inside a Flash client wether UDP connectivity is available?
          • 2. Re: test stratus availability
            zafer76 Level 1
            hi
            as Michael said there is no %100 solution. see the post below and remember why stratus is beta.
            http://forums.adobe.com/thread/698233?tstart=0
            in our game project http://apps.facebook.com/kickboxonlinefb/ users can select server manually.
            good luck...
            • 3. Re: test stratus availability
              Michael Thornburgh Adobe Employee
              if you can't connect to a Stratus server, then you definitely can't make any P2P connections, and you should connect to a regular RTMP server.  you can use the various failure events, such as NetConnection.Connect.Close, ...Failed, ...Rejected, or ...InvalidApp, or set a timer if you don't want to wait for the default timeout (like 60-90 seconds).
              same thing for P2P connections.  you can detect their eventual failure, or set a timer to time out before the normal time.
              if you find you're never getting P2P connections, or not even getting connected to Stratus, you could save that in a local shared object to speed up subsequent runs.  if you do that though, you should periodically re-try the RTMFP connection, since network conditions may have changed.
              there's no way to know for sure whether a connection will work unless you try it.
              • 4. Re: test stratus availability
                I've decided to just put a timer on the NetStream event, since the NetConnection always succeeds in the problem cases(there's a timer on that too just to be sure). If NetStream.Play.Start/Reset is not fired within x amount of time, I switch to FMS.
                Thanks for the suggestions!
