2 Replies Latest reply on Aug 16, 2010 4:03 AM by olsharpe
    Handling JavaScript Window Status Update..
    olsharpe
      I am developing a Flex/AIR application which renders HTML content from financial based system.
      I have created a subclass of the HTMLHost class in order to handle Javascript events such as window.open().
      This works well, but the web application in question stores session information with in the window status. I am having trouble to reflect this in my AIR native windows. Is it possible to make the status bar visible and display the data sent from Javascript?
      My HTMLHost subclass is as follows;
      package
      import flash.display.NativeWindow;
      import flash.display.NativeWindowInitOptions;
      import flash.display.NativeWindowType;
      import flash.display.StageScaleMode;
      import flash.geom.Rectangle;
      import flash.html.*;
      import flash.net.URLRequest;
      public class HtmlHost extends HTMLHost
      public var htmlControl:HTMLLoader;
      public function HtmlHost(defaultBehaviors:Boolean=true)
      super(defaultBehaviors);
      override public function createWindow(windowCreateOptions:HTMLWindowCreateOptions):HTMLLoader
      var initOptions:NativeWindowInitOptions = new NativeWindowInitOptions();
      initOptions.minimizable = false;
      initOptions.type = NativeWindowType.UTILITY;
      var bounds:Rectangle = new Rectangle(
      windowCreateOptions.x,
      windowCreateOptions.y,
      windowCreateOptions.width,
      windowCreateOptions.height);
      var htmlControl:HTMLLoader = HTMLLoader.createRootWindow(true, initOptions, windowCreateOptions.scrollBarsVisible, bounds);
      htmlControl.htmlHost = new HtmlHost();
      htmlControl.stage.nativeWindow.alwaysInFront = true;
      return htmlControl;
      override public function updateTitle(title:String):void
      trace ("TITLE UPDATE");
      trace (title);
      htmlLoader.stage.nativeWindow.title = title;
      override public function updateLocation(locationURL:String):void
      trace ("LOCATION UPDATE");
      trace(locationURL);
      htmlLoader.load(new URLRequest(locationURL));
      override public function updateStatus(status:String):void
      trace ("STATUS UPDATE");
      trace(status);
      override public function windowClose():void
      htmlLoader.stage.nativeWindow.close();
      Any help would be greatly appreicated!
      Oliver
