1 Reply Latest reply on Aug 11, 2010 6:02 PM by Michael Thornburgh
    adobe startus text chat broken @ connection setup
    StepanskyR
      Posted my question here, I think I may get some better support here.
      http://stackoverflow.com/questions/3453969/adobe-startus-text-chat-broken-connection-setup
      ^ You can look there for better actionscript formatting. ^
      Called with jquery using
      $("#flashtxtchat").get(0).startTxtChat()
      pretty much a javascript call to startTxtChat() which causes the fail.
      • ArgumentError: Error #2126:
      • NetConnection object must be
      • connected. at
      • flash.net::NetConnection/get nearID()
      • at textchat/startChat() at
      • Function/http://adobe.com/AS3/2006/builtin::apply()
      • at
      • flash.external::ExternalInterface$/_callIn()
      • at ()
      <?xml version="1.0" encoding="UTF-8"?>
      <mx:Application height="1" width="1" verticalScrollPolicy="off" xmlns:mx="http://www.adobe.com/2006/mxml" creationComplete="init()" backgroundColor="#EEEEEE" verticalAlign="middle">
      <mx:Script>
      <![CDATA[
      import flash.events.*;
      import flash.external.*;
      import flash.net.*;
      import flash.system.*;
      import mx.containers.*;
      import mx.controls.*;
      import mx.core.*;
      import mx.events.*;
      import mx.styles.*;
      import mx.utils.*;
      private var netConnection:NetConnection;
      private var sendStream:NetStream;
      private var receiveStream:NetStream;
      private var strangerPeerID:String;
      public function init() : void
      var url:* = FlexGlobals.topLevelApplication.url;
      var serverName:* = URLUtil.getServerName(url);
      if (!serverName.match(/(localhost|127.0.0.1)$/))
      return;
      ExternalInterface.addCallback("startTxtChat", this.startChat);
      ExternalInterface.addCallback("gotStrangerPeerID", this.gotStrangerPeerID);
      ExternalInterface.addCallback("sendMsg", this.sendMsg);
      ExternalInterface.addCallback("stopTxtChat", this.stopChat);
      ExternalInterface.call("flashtxtChat_init");
      return;
      }// end function
      public function startChat() : void
      if (this.netConnection)
      ExternalInterface.call("flashtxtChat_gotNearID", this.netConnection.nearID);
      else
      this.netConnection = new NetConnection();
      this.netConnection.addEventListener(NetStatusEvent.NET_STATUS, this.netConnectionHandler);
      this.netConnection.connect("rtmfp://stratus.rtmfp.net/key1-key2/");
      return;
      }// end function
      public function gotStrangerPeerID(param1:String) : void
      var _loc_3:NetStream = null;
      this.strangerPeerID = param1;
      var _loc_2:int = 0;
      while (_loc_2 < this.sendStream.peerStreams.length)
      _loc_3 = this.sendStream.peerStreams[_loc_2];
      if (_loc_3.farID != this.strangerPeerID)
      _loc_3.close();
      _loc_2++;
      this.receiveStream = new NetStream(this.netConnection, this.strangerPeerID);
      this.receiveStream.play("textchat");
      this.receiveStream.client = this;///temp added by me
      //this.strangerVideo.attachNetStream(this.receiveStream);
      return;
      }// end function
      public function sendMsg(msg: String) : void
      sendStream.send("recvMsg", msg);
      public function recvMsg(msg: String) : void
      ExternalInterface.call("recvMsg", msg);
      public function stopChat() : void
      this.strangerPeerID = null;
      return;
      }// end function
      public function netConnectionHandler(event:NetStatusEvent) : void
      var c:Object;
      var event:* = event;
      switch(event.info.code)
      case "NetConnection.Connect.Success":
      c = new Object();
      c.onPeerConnect = function (param1:NetStream) : Boolean
      if (strangerPeerID == null)
      return true;
      return param1.farID == strangerPeerID;
      };// end function
      this.sendStream = new NetStream(this.netConnection, NetStream.DIRECT_CONNECTIONS);
      this.sendStream.client = c;
      this.sendStream.publish("textchat");
      break;
      case "NetConnection.Connect.Failed":
      this.netConnection = null;
      ExternalInterface.call("flashCb_errorConnectingToStratus");
      break;
      case "NetConnection.Connect.Closed":
      this.sendStream.close();
      this.sendStream = null;
      if (this.receiveStream)
      this.receiveStream.close();
      this.receiveStream = null;
      break;
      default:
      break;
      return;
      }// end function
      </mx:Script>
      </mx:Application>
        • 1. Re: adobe startus text chat broken @ connection setup
          Michael Thornburgh Adobe Employee
          in your function startChat(), you say
          if the netConnection is in the process of connecting and startChat() gets called again, then the netConnection will not be null but will also not be connected.  you can only get the nearID if the netConnection is connected.
