3 Replies Latest reply on Aug 11, 2010 1:33 PM by Production Monkey
    Noobie needs help
    GSE1242
      Hi I'm currently creating a break-out style game just for fun.
      I have got the ball and paddle working and hit-detection etc but now I am trying to get the game to recognise when all the blocks have been destroyed.
      I need a piece of code that asks the system whether sprites 4-38 (the blocks) have all been hit by gBallSpriteNum (the ball).
      It then should go to frame 20
      I was trying things like
      if Sprite ("4-38") isVisible = 0 then
      go to frame 20
      end if
      But I am a noob and can't get it to work .
      Thanks for any help
      The code for hit detection on the blocks to make them invisible is the following:
      global gBallSpriteNum
      property spriteNum
      property my
      property isVisible
      property pBallSpriteNum
      on beginSprite me
        my = sprite(spriteNum)
        isVisible = TRUE
      end
      on enterFrame me
        if isVisible then
          if my.intersects(gBallSpriteNum) then
            _movie.sendSprite(gBallSpriteNum, #hit, point(1,-1))
            isVisible = 0
            my.loc = my.loc + 10000
          end if
        end if
      end
        • 1. Re: Noobie needs help
          Production Monkey Level 3
          There are many different approaches you could use but the fastest and simplest would be to just keep a count of the number of visble brick sprites.
          --  ball behavior
          property pVisibleBricks
          on beginSprite me
            pVisibleBricks = 35  -- or whatever the count is.
          end
          on hit me, aPoint, SpType
            if SpType =  #Brick then
              pVisibleBricks = pVisibleBricks - 1
              if pVisibleBricks = 0 then
                go to frame 20  -- you should use a frame label.
                exit
              end if
            end if
          end hit
          Then you call "hit" from the brick behavior thus:
          sendSprite(gBallSpriteNum, #hit, point(1,-1), #Brick)
          • 2. Re: Noobie needs help
            GSE1242 Level 1
            Hey. thanks for the reply. But when i input it the game just continues to play This is my ball script and brick script:
            -- ball script
            property spriteNum
            property my
            property pRightBound, pLeftBound, pTopBound, pBottomBound
            property pSpeed
            property pLifeCount
            on beginsprite me
              pVisibleBricks = 35
              pLifeCount = 0
              gBallSpriteNum = spriteNum
              me.mSetBounds()
              me.mStart()
            end
            on mSetBounds me
              sr = _player.activeWindow.rect
              pLeftBound   = my.member.regPoint.locH
              pTopBound    = my.member.regPoint.locV
              pRightBound  = sr.width  - (my.width - pLeftBound)
              pBottomBound = sr.height - (my.height - pTopBound)
            end
            on mStart me
              -- setting random direction and speed when ball starts.
              pSpeed = point(random(10,15) * [-1,1][random(1,2)], random(5,10))
              my.loc = point(200 + random(200), 300)
            end if
            end
            on enterFrame me
            tLoc = my.loc + pSpeed
            if tLoc.locH > pRightBound OR tLoc.locH < pLeftBound then
            me.hit(point(-1,1))
            exit
            end if
            if tLoc.locV < pTopBound then
            me.hit(point(1,-1))
            exit
            end if
            if tLoc.locV > pBottomBound then
            pLifeCount = pLifeCount + 1
            if pLifeCount = 10 then
            go to frame 60
            else
            me.mStart()
            end if
            exit
            end if
            my.loc = tLoc
            end enterFrame
            on hit me, ReflectionBias, aPoint, SpType
            pSpeed = pSpeed * ReflectionBias
                if pVisibleBricks = 34 then
                  go to frame 30
                  exit
                end if
              end if
            end
            -- brick script
            property spriteNum
            property my
            property isVisible
            on beginSprite me
              isVisible = TRUE
            end
            on enterFrame me
              if isVisible then
                  _movie.sendSprite(gBallSpriteNum, #hit, point(1,-1), #Brick)
                  isVisible = 0
                end if
              end if
            end
            • 3. Re: Noobie needs help
              should be:
              And
              should be:
              on hit me, ReflectionBias, SpType
