3 Replies Latest reply on Aug 12, 2010 7:55 AM by BenPleysier
    Spry Menu Bar- Display content below menu
      After playing around a bit in DW as I am still very new to it I have gotten a menu bar setup with the appropriate links. I have been using frames with the top frame that displays the menu bar and the bottom frame to show the content. This works but since each tab drops down 4-5 items i need to make the top frame longer so all items display but leaves a lot of white space when it is just the menu bar showing by itself.
      What other method is there that I can use  that will display the menu bar AND display the contents below it?  Im sure this wont be possible using frames so is there an easy way to do so in dreamweaver?
