3 Replies Latest reply on Mar 8, 2011 1:04 AM by MichaelBoo
    I18N and dataprovider
    mwoodpecker
      Hello,
      I'm trying to implement the internationlization for an application. The language should be changed at runtime that's why I use the resourceManger functionality of flex. My problem is that some of our app widgets liek comoboxes are using dataprovider in order to be filled. If I change the language these widgets are not updated. Here is some sample code:
      <mx:ComboBox id="combo" dataProvider="{comboArray}"/>
      the dataprovider is initialised in the onApplicationComplete method of the view
      comboArray = [{label:resourceManager.getString('language', 'form.value1.label'), data:"test1"},
      {label:resourceManager.getString('language', 'form.value2.label'), data:"test2"}];
      Can anybody give me a hint how to solve this issue or best practices?
      Regards,
        • 1. Re: I18N and dataprovider
          BhaskerChari Level 4
          Hi mwoodpecker,
          When you are changing the language of the application...try to rebuild the comboArray array and reset the dataprovider for your
          ComboBox.
          This will resolve the problem.
          Bhasker
          • 2. Re: I18N and dataprovider
            JabbyPandaUA Level 3
            Add to all your instances of  combo box (DropDownList in Flex 4) the following:
            override protected function resourcesChanged() :  void {
                    var storedSelectedIndex : int = selectedIndex;
                    selectedIndex = -1;
                    selectedIndex = storedSelectedIndex;
            • 3. Re: I18N and dataprovider
              MichaelBoo Level 1
              Hi!
              Did you find a solution ?
              Same problem for me.. I have a List component that is filled with ArrayList (or bindable variable). The label element have to be translate if  i push a button.
               <mx:ArrayList>
              <fx:Object label="{resourceManager.getString('i18n', 'strawberry')}" data="0"/>
              <fx:Object label="{resourceManager.getString('i18n', 'pear')}" data="1"/>
              </mx:ArrayList>
              What is inside my function when i push the button.
              ResourceManager.getInstance().localeChain = ["fr_CH"];
              Nothing is translated.... I already tried to use a [Bindable] variable with datas inside but still no reaction.
              In simple VBox is working...
              <mx:VBox id="testVBox"
              width="100%"></mx:VBox>
              Someone can help me please ?
              Thanks in advance.
