7 Replies Latest reply on Aug 13, 2010 12:24 AM by MarkTaylor46
    Local to Global Conversion
    Raphael_352
      Hello Flexperts,
      I would like to determine the position of a canvas in global coordinates, but I got something wrong I guess.
      Why does
      var topLeftGlobal:Point = _myCanvas.localToGlobal(new Point(0,0));
      return (0,0) when _myCanvas is not in the top left corner?
      Raphael
        • 1. Re: Local to Global Conversion
          rtalton Level 4
          It's returning 0,0 because you have specified those values when you created the new Point.
          Try:
          var topLeftGlobal:Point = _myCanvas.localToGlobal(new Point(_myCanvas.x, _myCanvas.y));
          • 2. Re: Local to Global Conversion
            Raphael_352 Level 1
            Thank you very much for your reply!!!
            The problem is still not solved though.
            If you look at
            http://livedocs.adobe.com/flex/3/html/help.html?content=containers_intro_5.html
            it seems reasonable to assume that the local coordinates (0,0) would lead to the top left corner postion in global coordinates.
            Message was edited by: Raphael_352
            • 3. Re: Local to Global Conversion
              Flex harUI Adobe Employee
              0,0 is your top-left in local coordinates.  The x,y values are the
              coordinates in the parent's coordinate space.
              • 4. Re: Local to Global Conversion
                Raphael_352 Level 1
                Yes, exactly (0,0) is top-left in local coordinates. That I know already.
                So why does globalToLocal(new Point(0,0)) return (0,0) ?
                • 5. Re: Local to Global Conversion
                  MarkTaylor46 Level 2
                  localToGlobal method does not work correctly until after the applicationComplete event has fired. it will not work correctly on  a creationComplete event.
                  Regards,
                  Mark.
                  • 6. Re: Local to Global Conversion
                    Raphael_352 Level 1
                    Yes, this is a very good comment. I made shure thought, that this computation happens after the initialization is fully completed and the component has been added to stage. By now I believe I have found a bug in the api and will try to produce a small example that reproduces it when I find the time.
                    Thanks for your efforts.
                    • 7. Re: Local to Global Conversion
                      Here is a working example that I used to prove that it works as expected. I hope this help you further testing.
                      <s:WindowedApplication xmlns:fx="http://ns.adobe.com/mxml/2009"
                                             xmlns:mx="library://ns.adobe.com/flex/mx"
                                             applicationComplete="init()">
                          <fx:Declarations>
                              <!-- Place non-visual elements (e.g., services, value objects) here -->
                          </fx:Declarations>
                          <fx:Script>
                              <![CDATA[
                                  private function init():void {
                                      var mcpoint:Point = new Point(_mycanvas.x, _mycanvas.y);
                                      var answerpoint:Point = _mycanvas.localToGlobal(mcpoint);
                                      trace(outsidebox.stage, _mycanvas.stage) ;
                                      trace(answerpoint);
                          </fx:Script>
                          <s:BorderContainer id="outsidebox" backgroundColor="#00ff00" width="500" height="600" x="10" y="10">
                              <s:BorderContainer id="_mycanvas" backgroundColor="#ff0000" x="10" y="10" width="300" height="500"/>
                          </s:BorderContainer>
                      </s:WindowedApplication>
                      Regards,
                      Mark.
