6 Replies Latest reply on Aug 22, 2007 4:15 PM by Newsgroup_User
    MPEG ADVANCE XTRA
    Vegas Star
      Hello Everyone!
      I need a little bit of advice. I created a presentation in Director using MPEG 1 video with the MPEG Xtra Advance. However
      the video won't play on my clients computer.
      The presentation plays on all my 3 three computers 2 of which are Mac and one PC with Vista.
      I need to insure successful playback, what is the best way to accomplish this.
      Kim
        • 1. Re: MPEG ADVANCE XTRA
          Level 7
          The xtra you cite should play MPEG1 files without nany software
          installation on any Mac/Windows machine.
          Does the video play back properly when you double-click the video file
          (that is, without involving your Director projector)? And if so, which
          application plays it?
          • 2. Re: MPEG ADVANCE XTRA
            Vegas Star Level 1
            Hi Sean,
            Thanks for replying to my plea. :) On my client's computer it will not open the video in either quicktime or windows media. However the individual file will open on both on all my computers (Mac and PC).
            I use a MAC to create the file. Is there a program that I could use that would create a MPEG1 that would work on both platforms.
            Originally the file was a .mov file created from Final Cut Pro. I created the .mpg from a program reccommended by apple iVCD.
            Kim
            • 3. Re: MPEG ADVANCE XTRA
              Level 7
              Which OS is your client running? What versions of WMP and QT are
              installed? Again, does the file open and play on their machine when
              double-clicked?
              • 4. Re: MPEG ADVANCE XTRA
                Level 7
                So basically, the next step is to figure out what is having the actual
                problem. Is it the movie file that is perhaps not a fully mpg-1
                compliant file? Or is the client's computer having problems playing
                digital video?
                I would start by seeing if the client's computer can play other mpg-1
                files (perhaps something created in a different piece of software). If
                the computer is not capable of playing mpg-1 files, then some software
                needs to be updated or a codec installed or something. That would be
                very odd, since every version of Windows since Win95 has been able to
                play standard mpg-1 files without needing any additional software.
                If the client machine can play other mpg-1 files, then there may be a
                problem with this particular file. Try recompressing it using different
                settings, or ideally, a different program entirely. Look up the mpg-1
                spec on the web. There are some specific settings that a file needs to
                have in order to be fully compliant. It may be that your program
                created a not-fully-compliant mpg that the client machine could not deal
                with.
                • 5. Re: MPEG ADVANCE XTRA
                  johnAq Level 1
                  Sounds like it might be the client's computer. Can it play MPEG-1 from another source?
                  hth
                  johnAq
                  • 6. Re: MPEG ADVANCE XTRA
                    Level 7
                    That's good advice that Mike provides. You could ask them to try playing
                    the MPEG1 file that ships with the MPEGAdvance Xtra demo - I would
                    imagine it's fully-compliant. If it turns out your file has problems (as
                    opposed to your client's machine), you could try compressing with
                    Tsunami: < http://www.tmpgenc.net/>
