1. Re: Accessibility Report-Incorrect Structure
HudginsRTR Sep 13, 2011 9:21 AM (in response to rjones888)I'm in the same boat, and on a deadline.
Were you ever able to figure this out? Thanks!
2. Re: Accessibility Report-Incorrect Structure
rjones888 Sep 13, 2011 12:58 PM (in response to HudginsRTR)I never found out why I was having that problem. I ended up combining all of the Word files into a single file and making the PDF file from the single Word file. After that we were able to run the accessibility report for the whole report.
3. Re: Accessibility Report-Incorrect Structure
CtDave Sep 13, 2011 9:00 PM (in response to rjones888)The following may have bearing on the situation.
The structure tree of a Tagged PDF that is inserted into an open Tagged PDF is always placed at the end of the open PDF.
This is true regardless of where the the inserted PDF is placed in the open PDF.If Combine is used to make a new, single PDF each PDF's structure tree lands at the bottom of what is in the file that precedes it.
Deletion of a page or pages does not remove the associated components of the structure tree.
The structure tree exist independently of the PDF page content.
While the Adobe PDF & the Section 508 full checks evaluate many aspects neither of them individually or collectively evaluate all requisite aspects of an Accessible PDF. Sometimes an evaluation of greater granularity is need; walk the structure tree from top to bottom with Highlight selected and cross-check pages using the Find Element feature.
Be well...
4. Re: Accessibility Report-Incorrect Structure
HudginsRTR Sep 14, 2011 10:45 AM (in response to CtDave)Thanks for the feedback. I have read something very similar, which might
have been posted by you or borrowed from you, in another forum. What I am
working on is a training manual, which consists of many images and elements
that would cause days worth of looking through the structure tree. The
document is 746 pages long. It is made of about 25 merged PDFs. I merged
them in order so it shouldn't be an issue about the tree, but with Pro 9, I
never know what to expect. My problem with the whole thing is that I can
merge a cover, title page, endorsement letter, and module 1 to find that
module 1 caused the problem. Or I can do just mod 1-4, and 4 will cause the
problem. Or if I start at the end of the manual, modules 20-16 may be fine,
but 15 is the problem. I've encountered a lot of issues with 508 because
what we do tends to be very complex, but this is a new one for me. Thanks
again for the feedback, though. I'm just glad to know that there are others
out here working on similar projects.
5. Re: Accessibility Report-Incorrect Structure
donapatrick Nov 2, 2011 2:50 PM (in response to rjones888)I'm having the same problem with a 540 page PDF files with lots and lots of data tables. The individual files chapters and appendixes all return no errors in the accessiblity report but when I combine them (all at once or one at a time) I evenutally get the "an incorrect structure was found in the PDF when I run an accessiblity check. I have Acrobat Pro 10.1.1 The soruce files were Word 2003 which I changed to Word 2007 before converting to PDF with all appropriate accessiblity options enabled.
This file was originally given to me as a PDF with strange things happening (tags disappearing, large sections of text not able to be tagged) so I tracked down the source files and tought I'd give it a go by tagging each chapter, testing them then combining them at the end. Now I get the structure error.
I'm ready to give up and say this is an impossible file.
Hoping someone has a real fix -- I've tried everything I've found with no success. I don't think combining the Word files and tagging them is an option since I have only about 16 hours left to finish this file. (I've been working on it for weeks)
Thanks...
6. Re: Accessibility Report-Incorrect Structure
HudginsRTR Nov 2, 2011 4:02 PM (in response to donapatrick)With 16 hours, you might be too late. I checked my document after
combining each chapter to narrow down the problem file. Then I looked
through the structure tree deleting sections until I found a smaller
problem area (still probably 100 pages). Then I checked every tag until I
found an image tag with no real image. It was a ridiculous solution, but I
finally found it. I know that provides little hope but it's the best I've
got. Good luck!
7. Re: Accessibility Report-Incorrect Structure
donapatrick Dec 1, 2011 9:42 AM (in response to HudginsRTR)Thank you for your response -- I never did figure out the issue, but it is good to know there is a fix. Sorry my thanks is so late.
