4 Replies Latest reply on Aug 12, 2010 12:31 PM by the_wine_snob
    MPEGs alone and with Menus....
    Pugio
      (new user, PE8, PAL-format)
      I normally assemble and save all mpeg-scenes from my Sony DCR-SR77E into one PAL DVD STANDARD MPEG movie in PE8 for later assembly with other movies (same type) under one DVD-menu. This DVD shows all movement in a terrible way - as if frames were dropped or switched around (but all in normal speed and in a very consistent way). In the beginning I thought the movie ended up in NTSC-format by accident - made from PAL-movies, but that is not the case. The problem is the same if I save my movies in AVI before assembling the DVD.
      If I choose to make a DVD directly from my Mpeg-scenes in PE8 (with or without menu) the result is perfect....
      I use the settings recommended in both cases.
      Does anyone have a clue what I am missing here?
      (Thanks in advance)
        • 1. Re: MPEGs alone and with Menus....
          the_wine_snob Level 9
          Welcome to the forum.
          The issue is likely that you are shooting to MPEG, which is heavily compressed to start. Then, you are Exporting/Sharing as MPEG, with another compression. Last, you are going to DVD, which will compress that footage to MPEG-2 one more time.
          Perhaps a better workflow would be to use a lossless intermediate file scheme, like the free Lagarith Lossless CODEC, to save one compression. Note: the file sizes will grow exponentially. You will need a lot of HDD space. You will still have two compressions (the original in the camera and the Transcode to DVD), but 2 will be better than 3. Motion, either camera or subject, will point up the compression artifacts most.
          • 2. Re: MPEGs alone and with Menus....
            You are most likely seeing interlacing. This is because you used the DV project settings rather than the settings for MPEGs and VOBs.
            Start a new project and this time select the project settings for DVDs and Hard Drive Camcorders. Your results should be perfect.
            • 3. Re: MPEGs alone and with Menus....
              Pugio Level 1
              BILL: No - that was not the solution, but you made me realize how terribly I treat my movieclips. I will certainly do as you suggest.
              STEVE: That did the trick. I have never even noticed that I should make a choice in that menu....
              THANKS a lot to both of you for the fast response and professional advice.
              • 4. Re: MPEGs alone and with Menus....
                Glad that Steve had the solution, and thanks for reporting.
                When starting with heavily compressed material, like MPEG-2, it is always best to induce as few additional compression steps, as is possible.
                Good luck and happy editing,
