1. Re: Add New Node - Adobe Director Microsoft Treeview Control 6.0 xtra?
SeanWilson Aug 12, 2010 1:32 AM (in response to RahulSolanki)Presumably you are accessing the control via Director's ActiveX xtra? If so, you need to read the documentation for the control in question - particularly the methods/properties it exposes to do what you require.
2. Re: Add New Node - Adobe Director Microsoft Treeview Control 6.0 xtra?
RahulSolanki Aug 12, 2010 1:39 AM (in response to SeanWilson)Right, I am accessing the control via Insert ->Controls -> ActiveX -> Microsoft Treeview. (unable to find any documentation)
I am actually trying to make a treeview and on selection do some stuff.
I have tried using CxtraPopup to create the same but when publishing it says unregistered version.
Can you please suggest any xtra that supports Menu.
3. Re: Add New Node - Adobe Director Microsoft Treeview Control 6.0 xtra?
SeanWilson Aug 12, 2010 1:19 PM (in response to RahulSolanki)When you insert the control, there are tabs available that show you properties, methods, events, ...
However, I had a quick poke around in the Treeview control and I too can't seem to populate the nodes.
Have you looked at Tabuleiro's TreeView Xtra?
4. Re: Add New Node - Adobe Director Microsoft Treeview Control 6.0 xtra?
xiaoyuandlg Apr 3, 2014 12:41 AM (in response to RahulSolanki)I tried on my own and it works. What happened, quite odd. I suggest that you check the TreeView control version?
