2 Replies Latest reply on Aug 17, 2010 2:05 AM by Abhin S
    How to add child
    Abhin S
      I am writing a code in which  i want to add child components i.e HBox6 to HBox4 on the click event of link button4
      code:
      <mx:Application
      xmlns:fx="http://ns.adobe.com/mxml/2009"
          xmlns:mx="library://ns.adobe.com/flex/mx"
        <mx:states >
          <mx:State name="si"/>
          <mx:State name="re"/>
          <mx:State name="de"/>
          <mx:State name="addchild"/>
        </mx:states>
        <fx:Script>
          <![CDATA[
            import mx.controls.Alert;
            import mx.core.Container;
            public function myLabelFunc(item:Object):String
                   return item.firstName + " " + item.lastName;
            public function myLabel1Func(item:Object):String
                   return item.firstName ;
        </fx:Script>
      <mx:VBox
           id="VBox1"
           top="10"
           borderSkin="skin.AppSkin">
         <mx:HBox
               id="HBox1"
                 horizontalAlign="center">
                <mx:ComboBox
                        id="ComboBox1"
                        includeIn="si"
                        labelFunction="myLabelFunc"
                        labelField="name"
                        prompt="Subject"
                        width="180" height="20">
                 <mx:dataProvider>
                 <mx:ArrayCollection>
                  <fx:Object firstName="Abhinav" lastName="Somal"/>
                  <fx:Object firstName="Adit" lastName="Kumar"/>
                  </mx:ArrayCollection>
                </mx:dataProvider>
              </mx:ComboBox>
              <s:TextInput
                     id="textinput1"
                  includeIn="re"
                  width="180" height="20"/>
              <mx:LinkButton
                  id="linkbutton1"
                   label="New Template"
                      click="currentState = 're'"
                      includeIn="si"/>
              <mx:LinkButton
                     id="linkbutton2"
                     label="Clear"
                     includeIn="si"/>
             </mx:HBox>
             <mx:HBox
               id="HBox2"
              <mx:ComboBox
              id="ComboBox2"
              includeIn="si"
              labelFunction="myLabel1Func"
              labelField="name"
                prompt="Filter Class"
                  <mx:dataProvider >
                  <fx:Object  />
                  <fx:Object firstName="B" />
                  </mx:dataProvider>
              </mx:ComboBox>
              <mx:LinkButton
              id="linkbutton3"
              label="New Filter Class"
              includeIn="si"
              click="currentState = 'de'" />
             </mx:HBox>
             <mx:HBox
              id="HBox3"
              <s:TextArea
              id="textarea"
              excludeFrom="de,addchild"
              text="The selected item is: {ComboBox1.selectedItem.firstName + ' '
              + ComboBox1.selectedItem.lastName};"/>
                <mx:Button
                     id="Button1"
                     label="Check Message"
                     includeIn="si"
                   click="Alert.show('Check Message Button is pressed','Alert Box',Alert.OK)" />
             </mx:HBox>
             <s:TextInput
                       id="textinput2"
                      excludeFrom="re,si"
            <mx:HBox
                id="HBox4"
                  <s:TextInput
                       id="textinput3"
                       excludeFrom="re,si"
                       width="50" height="20"/>
             <s:TextInput
             id="textinput4"
             excludeFrom="re,si"
             width="122" height="20"/>
             <mx:LinkButton
             id="linkbutton4"
             label="Add New"
             excludeFrom="re,si"
             click="currentState = 'addchild' ;
             </mx:HBox>
             <mx:HBox
             id="HBox6"
           <mx:TextInput
                id="textinput5"
                includeIn="addchild"
           <mx:TextInput
                id="textinput6"
              </mx:HBox>
              <mx:HBox
                id="HBox5"
           <mx:Button
                id="Button2"
                label="SEND"
                click="Alert.show('Send Button is pressed','Alert Box',Alert.OK)"/>
           <mx:Button
                id="Button3"
                label="Create"
                includeIn="de,addchild"
                click="Alert.show('Create Button is pressed','Alert Box',Alert.OK)"/>
           <mx:Button
                id="Button4"
                label="Cancel"
                click="currentState = 'si' ;
                Alert.show('Cancel Button is pressed','Alert Box',Alert.OK) "  />
         </mx:HBox>
      </mx:VBox>
      </mx:Application>
      Thnks...in advance
        • 1. Re: How to add child
          VRPDeveloper Level 3
          Then define hbox6 in state addchild... From your code it simple indicates that hbox 6 is already defined in base state... so there will be no effect...
          For EG
          <mx:State name="addChild">
                      <mx:AddChild relativeTo="{hbox4}" position="lastChild">
                         <mx:HBox
                 id="HBox6"
                      </mx:AddChild>
                      <mx:AddChild relativeTo="{canvas1}" position="lastChild">
                          <mx:TextInput
                    id="textinput5"
                      </mx:AddChild>
                     <mx:TextInput  id="textinput6" width="122" height="20"/>
                 </mx:AddChild>
                  </mx:State>
          Just given you sample you can make it in this way...
          If this post answers your question or helps, please kindly mark it as such.
          • 2. Re: How to add child
            Abhin S Level 1
            thnks for ur reply
            but by doing like this following error is ocurring:-
            State overrides may no longer be explicitly declared. The legacy states syntax has been deprecated in flex
