2 Replies Latest reply on Aug 25, 2010 10:47 PM by Royi A
    Graphs - Defining Parameters
    Royi A Level 1
      Hello.
      I'd like to define a parameter for Preview - "On", "Off" in Photoshop CS5.
      What would be the best way doing it within a Graph?
      May I define a Boolean parameter?
      I saw that in Kernels I can define "maxValueName" etc...
      Is it possible in Graphs as well?
      Thanks.
      P.S.
      Photoshop won't respect "maxValueName".
      Is there a way to create a bool / Int parameter in Photoshop with the writing On / Off?
      Thanks.
        • 1. Re: Graphs - Defining Parameters
          Royi A Level 1
          Is there a way in graph to define a Kernel to run only once?
          Let's say I'm doing a decomposition to an image into 3 images.
          I run the same Kernel 3 times with different parameters (The user doesn't control those).
          I get 3 images as a result.
          Now the user control the weighing of each decomposition in the new image which is a composition of each of them.
          The problem is each time the user changes the Weighing for each decomposition PB would recalculate the whole 3 Decomposition all over again.
          Is there a way to prevent it?
          Something like telling the node you run 3 times (Each time with different Parameters) and that's it. from now on the results are 3 Constant images for the next Node to handle (With user Parameters).?
          Thanks.
          • 2. Re: Graphs - Defining Parameters
            Royi A Level 1
            Bob / Kevin?
