0 Replies Latest reply on Jul 31, 2007 2:24 PM by in480
    Show/Hide Effects Not Running At The Correct Time
    in480 Level 1
      I have a panel that I use show and hide effects on to have it appear to slide out from the side.
      My problem is that I have multiple states that each set the panel's visibility to true and add their own objects to the panel. The problem occurs when the panel is visible and I switch into another state that also has visibility set to true.
      When I do this, the panel does it's Hide effect and disappears, even though the state I entered is setting it to true. If I remove the Hide Effect, this behavior goes away and the panel stays visible like it should.
      What would cause the Hide effect to trigger when the panel's visibility is set from true to true?
      Thank you for any help.
