In the check box if I move the text to the top and then center the text – how do I get the check box to be centered under the text?
Views
Total Likes
Not sure I understand your question ....how do you get the checkbox to what?
Paul
Views
Total Likes
When you use the check box the text is on the right side of the square check
box, but you can move the text to the top, left or bottom of the square. I moved
the text to be on the top and I centered the text in the field. I want to have
the square check box to be centered also. Is there a way to do that?
Views
Total Likes
No I do not believe so .....I woudl not use a caption and use a separate text object for the caption. Then you can control each object independantly.
Paul
Views
Total Likes
