1 Reply Latest reply on Aug 2, 2007 3:10 PM by ntsiii
    Refresh the Application
    status_bar
      The problem I am facing is that , the application is not refreshed when i press the logout button and go back to my main page(Login page). when I again go to other screens from login page the data stays as it was earlier before logout, i.e the inner screens are not refreshed. Right now iam using navigateToURL method to overcome this problem .Is this the right way or there is any other alternative .
      amar
        • 1. Re: Refresh the Application
          ntsiii Level 3
          It is the simplest. And I frankly see no reason not to use it. It is much easier than manually setting every control and data structure.
          The SWF is cached, so if the app is reasonably well crafted, the performance should be ok.
          On the other hand, if the app is data driven, you could simply empty the data structures, and all the UI would follow.
          Tracy
