3 Replies Latest reply on Aug 13, 2010 4:24 PM by Alex6377y
    UpdaterUI does not work when using isNewerVersionFunction
    stevetx2
      When using isNewerVersionFunction in  Air 2..02  and 2.0.3  the Update screen appears  very shortly and then closes.
      When reverting back to Air 1.5.0.7220 it works fine
      private var appUpdater:ApplicationUpdaterUI;
      private var _host:String = new String;
      private function checkForUpdate():void {
      appUpdater = null;
      appUpdater = new ApplicationUpdaterUI();
      // Server-side XML file describing update
      appUpdater.updateURL = "http://" + _host + "/FlexBuild/" + xmlUpdateFile;
      setApplicationVersion();
      appUpdater.isNewerVersionFunction = customUpdaterVersions;
      appUpdater.isCheckForUpdateVisible = false;
      appUpdater.addEventListener(UpdateEvent.INITIALIZED,onUpdate);
      appUpdater.addEventListener(ErrorEvent.ERROR,onError);
      appUpdater.addEventListener(StatusUpdateEvent.UPDATE_STATUS,appVersions);
      appUpdater.initialize();
      private function onError(event:ErrorEvent):void {
      Alert.show(event.toString());
      this.maximize();
      private function onUpdate(event:UpdateEvent):void {
      appUpdater.checkNow(); // Go check for an update now
      private function customUpdaterVersions(currentVersion:String,updateVersion:String):Boolean {
      try{
      log.info("server version "+Utilities.trim(Properties.getString("VERSION"))+ ", Appversion"+Utilities.trim(version));
      if (Utilities.trim(Properties.getString("VERSION")) != Utilities.trim(version)) {
      return true;
      }catch(e:Error){
      log.fatal("ERROR IN customUpdaterVersions"+ e.toString());
      log.fatal("STACK Trace"+e.getStackTrace());
      return false;
      private function appVersions(evt:StatusUpdateEvent):void {
      var serverVer:String = Utilities.trim(evt.version);
      var clientVersion:String = Utilities.trim(evt.currentTarget.currentVersion);
      log.info("Cleint Application Version Number: " + clientVersion);
      log.info("Cleint XML Application Version Number From Server: " + serverVer);
      //log.info("appUpdater information "+ ObjectUtil.toString(appUpdater));
