6 Replies Latest reply on Aug 14, 2010 12:14 PM by kglad
    Play animation (movie clip) randomly as3
    spinkowalski Level 1
      Hello,
      Could anyone out there tell me what as3 code i should be using to make this happen.
      I want the animation (shooting star) to play at random times.
      Many thanks indeed.
      Damien
        • 1. Re: Play animation (movie clip) randomly as3
          what's the instance name of your shooting star movieclip?  does it have a stop() on its timeline?  if yes, which frame?
          • 2. Re: Play animation (movie clip) randomly as3
            You can use the Timer class and have the delay property reassigned as a randomly calculated value each time the Timer fires.
            • 3. Re: Play animation (movie clip) randomly as3
              The movie clip is called 'starmove'
              Its placed on the first frame, no 'stop' in the actions, it just loops in the same position and time.
              Preferably I would like various instances in different positions to randomly play, to give the effect of real shooting stars.
              Any help gratefully received
              Damien
              • 4. Re: Play animation (movie clip) randomly as3
                on the last frame of your movieclip attach:
                stop();
                this.dispatchEvent(new Event("finished"));
                right click your movieclip in the library, click linkage, tick export for actionscript and assign a class (eg, Starmove).
                you can then use:
                var minTime:uint = 1000;
                var maxTime:uint = 3000;
                var timer:Timer=new Timer(timeF(),0);
                timer.addEventListener(TimerEvent.TIMER,starF);
                timer.start();
                function starF(e:TimerEvent){
                var star:Starmove=new Starmove();
                addChild(star);
                star.x = Math.floor(Math.random()(stage.stageWidth-star.width));  // these two will probably need adjustment
                star.y = Math.floor(Math.random()(stage.stageHeight-star.height)); // ditto
                star.addEventListener("finished",removeStarF);
                timer.delay = timeF();
                function removeStarF(e:Event){
                removeChild(e.currentTarget);
                e.currentTarget.removeEventListener("finished",removeStarF);
                e.currentTarget=null;
                function timeF():uint{
                return minTime+Math.floor(Math.random()*(maxTime-minTime));
                • 5. Re: Play animation (movie clip) randomly as3
                  Hey Kglad, thank you.. movie plays the same as without your code (no change) in a loop, and there are two compiler errors:-
                  Scene 1, Layer 'Layer 2', Frame 1, Line 24 1118: Implicit coercion of a value with static type Object to a possibly unrelated type flash.display:DisplayObject.
                  Scene 1, Layer 'Layer 2', Frame 1, Line 26 1059: Property is read-only.
                  Any ideas?
                  • 6. Re: Play animation (movie clip) randomly as3
                    use:
                    timer.start();
                    addChild(star);
                    removeChild(MovieClip(e.currentTarget));
